Question about Brother DCP-110C All-In-One InkJet Printer
Factory reset paper jam
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Paper Jam error message - no jam
Can you try to go to webinterface by typing ip address on the browser menu
here you can reset to factory setting
Oct 30, 2009 | HP LaserJet 2420 Printer
Paper Jam when it is not jammed. Can't print.
It could be an issue with the printer, make sure that there is no paper jam or check for any tiny bits of paper is side the printer, that could cause the issue.
However try reseting the printer
Follow the below steps to reset the printer;
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
This should fix the issue.
Sep 27, 2009 | HP Officejet 5510 All-In-One Thermal...
How do i reset a canon mp210 to its factory settings. It is flashing E3, which indicates a paper jam, but there is no paper in the machine or a jam.
Buddy its simple, Just remove the power cord and printer cord. Keep it like that for 5 minutes. then restart your printer thats your factory reset. It its not working then your paper sensor is u/s you need to replace it.
Kindly vote if it solves ur problem.
Jun 28, 2009 | Canon PIXMA MP210 InkJet Printer
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Aug 20, 2008 | Lexmark E340 Laser Printer
Brother DCP-110C All-In-One InkJet Printer Logo
14 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
