Operating manual for defy zbc-15 ice cube maker
huuum
  • 750 Answers
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Posted on Oct 12, 2008
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Posted on Jun 19, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
woodchuck789
  • 4070 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
Ice cubes are too thin. Making on time, but no volume due to small cubes. What part will correct this?
Well this thing is made to make ice cubes so if the ice cube are to small thin then you water supply must be restricted because its cold enough to make the ice just the volume of water isn't their .Check the feed system for restrictions .
Jun 01, 2015 | Whirlpool Gold Series GI15NDXT 15"...
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
Ive just put a new grid cutter in my whirlpool ice maker but it is not heatinh up to cut the ice sheets into cubes. Any ideas what to do next?
Yes the next step is to check the voltage on the secondary side of the grid transformer found in the photo on page 30 of the=> 15 and 18 inch Whirlpool Ice Maker Service Manual
GI15NFLXS Grid Transformer
I hope the manual is a big help in resolving the ice cutting problem and please ask should you have any questions. The secondary side of the transformer should be showing a least 8.5 volts ac. Let me know if you are able to find the problem, Thanks Sea Breeze
The 18 inch ice maker takes the same grid transformer as the 15 inch model.
Mar 15, 2013 | Whirlpool Refrigerators
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
My ice maker wont make ice. What should I check
Is the freezer temp at least -15 degrees? Is there water to the water valve in the back? Is there a cube stuck in the harvest arm of the ice maker? Is there water in the tray of the ice maker?
Sep 11, 2009 | Refrigerators
Ice cubes are hollow
The proper amount of water is not entering the freezing chamber. A few things to check; look for a crimp in the tubing behind the refrigerator; there is a dedicated water cut off for the supply line, make sure the valve is turned to the on position. Also look in the ice bin and make sure an old ice cube isn't stuck somewhere preventing the metal bar from operating proprely. And just for the sake of having done it: Raise the metal bar to the UP position allowing the ice maker to remain OFF for 15 min.
Aug 25, 2009 | Refrigerators
Automatic Ice Maker making grinding noise and will not release ice
The mold heater on the bottom of the ice maker is shot, that is why the cubes will not release. The grinding is the sweep arm trying to push the frozen cubes out.
May 06, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 27, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice Maker will not dispense ice cubes only crushed ice
sounds like the circuitry on your Cubed Ice button has malfunctioned. Contact the manfacuturer for a solution.
in the meantime, u can grab the Cubed ice manually.
hope this helps!
Jun 16, 2008 | Frigidaire FRS26R4A Side by Side...
Open Questions:
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
