Question about Casio Exilim EX-Z77 Digital Camera
Card Locked shown when turn on camera
On turning on my camera it says Card Locked, I cannot find my instructions please help Thanks
  • nickromeril May 21, 2009
    Thank so much for your prompt reply, works great thanks.
  • wuoloo May 25, 2009
    My Casio Exilim EX-Z20 fell on the ground and showed the Card Locked sign on switch on. I have since reformatted the card, and also moved the switch on the side of the memory card severally with no positive response.
  • 51 Answers
Switch off your camera....unplug your card....there will be a small unlock sliding switch on its side....just slide it and then try to insert it back and use it...should work fine.
Posted on May 21, 2009
Card locked error on samsung es80
Turn off the camera and remove the memory card.Most cards have a lock slider at the side.You have to slide that button downwards/upwards to unlock it.Slide the memory card back into the camera.
Turn on the camera.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Samsung Cameras
When i turn on my camera it says the memory card is locked there is nothing wrong with the memory card how do i reset the camera
You have to remove the lock of the memory card by sliding the write protect tab as shown below.Please rate me as helpful if satisfied.Good lucktinualbinale_0.png
Jun 05, 2011 | Canon PowerShot S2 IS Digital Camera
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
Card locked please help
There are two reasons for card locked problem Canon PowerShot A400.
One is card locked while camera opening. The answer for this is explained in below figure.
34a2e3d.jpg The other one is dealing with card itself. The below picture shows that.
68ed342.jpg You may need the user manual for other problems.
This is User Manual of Canon PowerShot A400
If you find this helpful please vote.
Mar 04, 2010 | Canon PowerShot A400 Digital Camera
My camera shows CARD LOCKED
Try taking the card out of the camera and clicking the side of the card - there may be a little gap on one side of the card or a small button that you can slide up and down and then reinsert your card.
Apr 27, 2009 | Pentax Optio E10 Digital Camera
PLEASE HELP.
someone595,
Don't panic, keep in mind to turn off the camera before you remove the SD card or change lenes. Charging the battery shouldn't take too long put it back in make sure the lens is properly locked in place, put in the SD card in then turn it on and you should be good to go. let me know I'll check back in an hour to see if that helped.
randy320sgi
Jan 06, 2009 | Nikon D70s Digital Camera
Screen reads SD CARD locked
I have 17 of these cameras and for some reason after a while some of them develop this problem. It is very frustrating but I can usually get them to work by taking disk out, turning on camera, put in auto mode, wait for delay to switch to ready then put card in. I works most of the time and if not turn it off and keep trying. Some kind of glitch in the computer I guess. Hope this helps.
Nov 23, 2008 | Moultrie MFH-DGS-100 Digital Camera
Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 10, 2007 | Pentax Optio 550 Digital Camera
Card Locked
remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
Nov 04, 2007 | HP Photosmart R707 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Casio Exilim EX-Z77 Digital Camera Logo
106 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
