Question about Tvone TV-207 Television
Screen zoom to narmal possison
With remote
How do I make the screen on my sanyo tv full- It has a black bar top and bottom
Your TV remote control (not the cable box remote control) would have to have a button that would allow the changing of the TV screen sizes. My Sony TV control has a button called, ' wide', and when pressed will change my screen to either, full, wide zoom, and zoom. Only zoom gets rid of the black bars on my TV. If no button, than the screen size will be determined by the broadcaster.
Feb 10, 2013 | Sanyo DP26640 LCD TV
Where is the ZOOM button on the remote?
There are som remote control, that doesnot have zoom. However you must read the instruction manual. IF you do not have download for free.
www.fitness.manualsonline.com or www.retrevo.com
God bless you
May 08, 2012 | JVC RM-C18G-1H Remote Control
The Screen is zoomed in and we dont have a remote or a manual for the tv what can we do
not sure what model tv you have but there should be a menu on the tv. seach thru it and select the zoom option if not. shut and unplug the tv for 20 minutes that will reset it back to factory settings for you let me know if this helps!
Mar 16, 2011 | Televison & Video
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
How to format my PHILIPS flat screen. I want the picture to be full screen
On the picture menu, you can select between 16:9, 4:3, zoom 1, zoom 2, etc. Depending on the station you are watching and whether or not it is an HD station, selecting zoom 1 or zoom 2 on your TV remote might give you full screen. Otherwise, on some DISH remotes there is a format or zoom button that will also change the size of the picture.
Feb 27, 2011 | Philips Televison & Video
TV zoomed in
Look at your remote or On-screen menus for ratio settings. The remote might say zoom or ratio. The menus will probably have it under video and then Aspect Ratio. You'll probably need to hit go through several settings to get to the correct ratio. (some choices are 4:3, 16:9, Full-screen - the best choice depends on the set and the source video)
I hope this helps.
(my remote (slightly different TV) has the zoom just above mute so I hit the wrong button often.)
Apr 24, 2010 | RCA 36V550T 36" TV
HD TV screen is zoomed to far out. How do
Use the Picture, Zoom, or Aspect button on the TV remote to cycle through the available screen sizes. You may also be able to set screen size in a Setup-Picture (or Video) menu.
Jan 18, 2010 | Televison & Video
Picture is too big for screen
You will have a button on the _original_ remote that says Format, Aspect Ratio, Zoom, Size or just AR. It will cycle through Normal, Stretch, Partial Zoom, Zoom, Gray Bar, or the like. You are not in Normal but in one of the Zooms. Stretch is used to make 4x3 movies fill a 16x9 screen, may not be desirable. Zoom is used to fill the 16x9 screen with movies that have been letter boxed. Gray Bar fills the sides of a 4x3 picture on a 16x9 set with gray to "avoid" burn in. Use normal except zoom on LB. -Ken
Oct 04, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
My screen size is in the 2X mode. I cannot get the screen size back to normal. Of course I lost the owner's manual. I have tried all the buttons on the remote w/o success.
the bottom half of the remote slides down ... that will reveil lots of lesser used controls including zoom .. you can also get to zoom via the menu system .. but its easier to just slide open the bottom cover on the remote and push zoom ..
Sep 28, 2009 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
Top Tvone Televison & Video Experts
romy sibug
romy sibug
Computer Repairing
Computer Repairing
Falling star
Are you a Tvone Televison and Video Expert? Answer questions, earn points and help others
