Power protection circuits won't reset
I am an electronics tech... Receiver goes into power protection as soon as it is turned on. I tried a factor reset. I have the service manual. What I need to know is... " Is this most likely a transistor on the final amp heat sink? Is there anyway of isolating bad component without removing heat sink board, transistors and checking them individually with an ohm meter? There is major dis-assembly involved to get the board out.. Am I overlooking anything? Anyway of isolating to board without disassembly?
  • 9 more comments
  • Paul Schuster Jan 02, 2014
    should read, " I tried a factory reset using power on with front panel button."
  • jason Jan 02, 2014
    Visual on caps , resistors on amp,volts flash on spkr output ,power flash to amp on the heatsink ?
    What kind of test have you done ?
    One side of one of the resistor banks was open.. I took it apart and checked power transistors in that area and then all of them.... I have 4 in that channel and 1 in the other channel reading wrong.. several are shorted c-b, e-b- and even c-3...Having trouble with the service manual parts lists for ID.. Where do I buy parts and / or find replacement transistor numbers?
    transistors were checked by unsoldering b and emitter leads and doing an ohmmeter reverse reading check..
    you don't see numbers on the front of the transistors ?
  • Paul Schuster Jan 03, 2014
    yes I found numbers... these are what I need, but sometimes numbers are just mfr ref nrs.... I need KB817Y and KD1047Y. These are listed as power triodes. I haven't heard this term used since I worked on tubes..What I need now is to know where I can purchase them. I also need a RSS2WK-0.22 resistor part.
    continued...There is no NTE cross reference that I can find and Alabi (china quantity order seems to be only thing out there so far). The onkyo manual for some reason does not have the finals in their parts list within the service manual..
    Found part numbers. Part Number in manual shows slightly different transistor designation than what is printed on xsistor to add to the confusion.. KTB817Y Part Nr. 2203624 and KTD1047Y part nr.2203634 .
  • Paul Schuster Jan 07, 2014
    Found parts... but had to order from China..mcm electronics and aliexpress.
  • joe daniels Jan 10, 2014
    remove speaker wires and subwoofer.then power up to check if it shut down .wires could be shorted
  • Audio Service Clinic Jul 06, 2014
    If you have done a factory reset, and you still have an LED flashing, you have DC Offset. There is a way of isolating the amp channel that is causing the offset, but once you are there, you will have to go through all the motions to test the most likely parts. Do not try to replace a board, as there is very little tech support to authorize anything. I should know....If this is out of warranty, there is no way your customer will authorize a board replacment plus labor. No, there is no simple way of repairing this. You can isolate the bad channel before you take it apart, but once that's done, you will have to physically remove all the boards, as there is no bottom cover. Forget looking for bad capacitors. Those issues peaked in 2002, and almost never were these caps used in an amp. If you would like to discuss a repair, you can contact me at my website, audioserviceclinic.com. Thank you.
  • 899 Answers
This is a good place to get components http://www.rselectronics.com/
also here http://www.digikey.com/
Posted on Jan 02, 2014
Testimonial: "None of these suppliers as well as Allied, Newark and others have these..There are no cross references as well including NTE."
    Genius:
  • Audio Player... Master
  • 1,054 Answers
What brand/model of receiver are we talking about?
Testimonial: "Onkyo TX-500sr... At this point i just need to know where to buy finals... what they are calling power triodes.. KB817Y and KD1047Y as well as the resistor pack RSS2WK-0.22."
2 Suggested Answers
SOURCE: Amp Protection Mode
from LANCE P: I fixed it. Be sure that all your speaker connections are perfect. No element frays that can arc, no +/- problems, no single barely connected wire. My problem was volume sensitve and I evidently had one + wire that was loose in the back. I corrected it and ran it all day with surround and good volume with no problems. So diligently check ALL YOUR SPEAKER CONNECTIONS, both in the back of the unit and at your speakers
Posted on Mar 31, 2008
My Onkyo TX-SR700 AV Receiver shuts off about 10 seconds after I turn it on ?
Please remove speaker wires from receiver and turn it ON, if receiver still goes to standby that means it got problem in amplifier output section and protection circuit gets activate to turn it off.
If removing speakers solve turn-off problem that shows any of speaker is bad, connect speakers one by one to find out what speaker causing protection circuit activation.
And if receiver has problem with internal circuit, a tech would be fine to diagnose that kind of problem because it is not user level repair as it requires testing voltages in output circuit of receiver and also requires soldering work to replace defective parts.
Thanks.
Sep 12, 2009 | Audio Players & Recorders
The tv will not turn on
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Jul 15, 2009 | Broksonic CCVG-3276 32 in. LCD TV
TV KEEPS TURNING OFF BY ITSELF
connected.
May 06, 2009 | Samsung HL-S5086W 50" HDTV
LCD LIGHT BLINKS
connected.
Apr 19, 2009 | Uniden Lands Phones
No picture and no sound
If you have a blue screen on tv, try changing source with the remote control, and check connection cable to source.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
connected.
Mar 28, 2009 | Vizio VW37L 37 in. LCD HDTV
Wd-62525 tv timer light still flashing green even after turning set off and hitting reset button
connected.
Feb 22, 2009 | Mitsubishi WD-62526 Projection TV
Tv won't turn on
connected.
Nov 17, 2008 | Insignia LCDTV26 26 in. Television
Power flashing on and off
connected.
Aug 14, 2008 | RCA F27TF700 27" TV
Tv problem
connected.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
TV Turned itself off and on with flashing green power button
connected.
Sep 03, 2007 | RCA F27718 27" TV
432 people viewed this question
 Grubhead
Grubhead
