Question about Zyxel P660HW-D1 Router
Reset the password WITHOUT resetting the entire router to default
  • 13,433 Answers
There is no way for you to get into the router without the password unless you make it restore to defaults.
you have to perform the reset and everything will be on defaults. no other way.
Posted on May 21, 2009
2 Suggested Answers
MilT0N
  • 6 Answers
SOURCE: Can't log into my router
No there is not a way to just change the password on these devices. If you have changed the password from the default and either forgot it ,or fat fingered it upon entry then you will need to do a hard reset which resets everything. However the config's on these are so simple it shouldn't take longer than 10 min to reconfigure it, especially if you have good documentation!
MilToN
CNA, CNE, MCSE, CCNA, Network +
Posted on Nov 26, 2007
How to change password of dlink router 600 without reset
the default dlink password is password or 1234
if that doesn't work then the password has been changed and you will need to reset the router to factory defaults. hold the reset button for 30 seconds while powered on.
Mar 04, 2012 | D-Link DIR-600 Router
I changed the default password, and I forgot it. How can reset the password, without lost the configuration?
There is no way to recover the password unless you reset it to factory defaults. This would mean losing your current configuration. I would try to guess everything you can possibly think of. If you still can't figure it out you need to reset to factory settings. To reset factory settings there is a button on the back of the router that says reset. Hold this down for 30 seconds and everything should be reset.
May 17, 2011 | Zonet (ZSR0104UP) Router
How can I find or reset my password for my netgear.
The default login information for that router is
Username = admin
Password = password
If you or someone else changed it from the default information though, then you will have to reset the entire router back to the default settings.
You can do that by finding the reset button on the back of the router (it is a small button in a pin-hole).
Using a ball-point pen, press on the button and hold for 30sec. This will reset your router to the factory defaults and the login information I posted will work, but you will have to input all of your router information again.
I hope this helps. If not, please comment back and let us know!
Jan 06, 2011 | NetGear WGR614 Wireless Router
Need password to internet
You can't.
What you can do is reset the entire router. There should be a button on the back you can press in with a paper clip, hold it down for a few seconds, lights should flash.
Your router will then be reset to factory defaults. Without any more information I can not tell you how to find the default user/pass to log in.
Apr 08, 2010 | Computers & Internet
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Apr 03, 2010 | NetGear DG834G Router
I CANNOT LOG IN TO MY ROUTER
You can do a reset on the Router to return to factory default. You can press the tiny reset button using any pointed object or with a paper clip. After that, you can already login to the router using default access. Open http://192.168.0.1 in a browser and use "admin" as username and "password" as your password.
Nov 19, 2009 | NetGear WGR614 Router
Forgot router login for netgear router wgt624
Reset the router from back , Hold the reset key for 30 sec , Make sure router is powered on , Turn off the router for 30 secs and then turn it back on , Your router login would be username : admin and password : admin factory default
Regards:
Chandan
Sep 07, 2009 | NetGear WGT624 Wireless Router
Cant get into router settings to put in ssid & network key
Use the Default Reset button on the rear panel of the router. Use this method for cases when
the administration password or IP address is not known.
Using the Reset button
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
the defaults will be applied ie;
192.168.0.1 or 192.168.1.1 and admin/admin
Mar 12, 2009 | NetGear DG834G Router
Router password
Before following this procedure beware that the reset function on the router will probably reset the entire configuration to the factory original. You will probably need to completely reconfigure your router after the reset including WAN side IP address or dynamic and possibly PPPoE userid and password if required by your ISP.
click on the following link
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US%2FLayout&cid=1175238819816&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1981633391H10
select your region and country
Select Choose a Product
Enter your product or navigate to it.
Download your user guide.
It should have instructions for resetting the router as well as reconfiguring the router.
Dec 08, 2007 | Linksys Wireless-G Broadband Router
MilToN
Nov 26, 2007 | Arris SBG1000 Wireless Cable Modem Gateway...
Zyxel P660HW-D1 Router Logo
1,568 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
