Question about Konica Minolta Office Equipment & Supplies
Clearing trouble code C-D252 on Bizhub 253c - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,168 Answers
Missing the a circuit board for you print controller
Posted on Jul 03, 2016
2 Suggested Answers
  • 1297 Answers
SOURCE: Trouble code C-D252
The CD codes refer to imaging process abnormality.Try to reset by :
Turn OFF the copier,keep pressed the Utility key and turn ON the copier.Keep pressed the Utility key when on the screen appeir Trouble reset.Touch the message and turn OFF the copier.Wait 1 minute and turn ON.
Posted on Jan 02, 2014
BIZHUB 223 ERROR C-D252
Go to 'System 2' in service manual
Touch 'Image Controller'. Button.
Select 'Controller 0' for the standard controller.
Exit and Power Off and On
Jul 15, 2017 | Konica Minolta Office Equipment & Supplies
Put in a firery now machine gives error code c-d252 hw do i remove that
Missing the VI-505 relay board. Also check in service mode that the Image Controller setting is set to 0. Also mite have a bad main board, and or relay board if installed.
Oct 21, 2015 | Konica Minolta Bizhub C360
Trouble code C-D252
Jan 02, 2014 | Konica Minolta Office Equipment & Supplies
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit.
Mar 13, 2012 | Konica Minolta Konica Bizhub C353 Drum...
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Err c 0500
This error code is a fuser problem and maybe in my experience a morning problem.
Try to clear the error the error with this procedure:
Hold down utility counter for 3 seconds and in the screen will appear a trouble reset, then touch it and turn off and on the main, it will clear the error code.
If it does not see if you have fuser problems with the termisotrs and also check the power.
Jul 21, 2010 | Konica Minolta Bizhub 222 Black and White...
How to clear error code c 3421 on konica bizhub c253
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
May 19, 2010 | Konica Minolta bizhub C250 All-In-One...
PRINTER TROUBLE CODE C-0210 KONICA MINOLTA
on previous models with this code check that there is no paper caught behind the tray open and close door to clear code
Feb 11, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
1,137 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
