JPW1 When I connect the power supply to the jpw1, I hear three beeps and the system won't load at all.
  • 979 Answers
Hello Zarko, hi, make sure you have connected also the 4 pin molex 12 volt plug (square yellow & black), check also your RAM, the three beep is a display problem, so check your VGA ports and graphics card
Posted on Jan 03, 2014
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: jpw1 problem. When i place
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help don
Posted on Mar 14, 2011
MSI 845GVM-V (MS-7057-010) Motherboard cpu fan not ruuning but smps is ok when jpw1 is disconnected then fan is running but mother board is not on
Hello hare is the homepage:
http://www.msi.com/product/mb/845GVM-V.html#/?div=Manual
Try to download the manual, and check all your connections again.
Try also to renew the power supply.
Check also this site:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
The jpw1 is the main power connection for power to the cpu:
So you probably have a bad power supply.
Good luck
Jan 25, 2013 | Computers & Internet
WHEN JPW1 PORT I S CONNECTED THEN MOTHER BOARD CPU FAN IS JUST ON AND OFF WHAT IS THE SOLUTION OF THAT SMPS IS OK.
Good luck
Jan 25, 2013 | MSI 845GVM-V (MS-7057-010) Motherboard
SuperMicro H8QG6-F Continous Beep
http://www.supermicro.com/Aplus/motherboard/Opteron6000/SR56x0/H8QG6-F.cfm
Under the Link and Resources heading, in the blue banner to the right, click on - Motherboard Manual
Page 32 of the PDF file. Page 2-10 for the manuals actual page,
2-7 Connector definitions:
Power Connectors
"A 24-pin main power supply connector (JWP1), and three 8-pin CPU PWR connectors (JWP2 / JWP3 /JWP4) on the motherboard.
These power connectors meet the SSI EPS 12V (Volt) specification.
In addition to the 24-pin ATX power connector, the 12V 8-pin CPU connectors at JWP2 / JWP3 / JWP4, MUST be connected to your power supply.
Warning: To prevent damage to the power supply or motherboard, please use a power supply that contains a 24-pin and three 8-pin
power connectors.
Be sure to connect these connectors to the 24-pin (JPW1) and the three 8-pin (JPW2,JPW3 and JPW4) power connectors on the motherboard.
Failure in doing so will void the manufacturer warranty on your power supply and motherboard."
So there you have it.
YES.
These,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
NOT these,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 02, 2012 | Super Micro Computer SUPERMICRO H8QG6-F
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
Jpw1 problem. When i place the jpw1 cable for my MSI 845GV ICH4 my board didn't get any supply from power supply. If i take off the jpw1 cable then i turn on switch, the fan is on. only when i place the...
Mar 14, 2011 | MSI 845GVM-V (MS-7057-010) Motherboard
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
When turning on the power everything starts as normal but then the system stops and beep. The fans keep turning but you can no longer hear the power supply going.
Either the power supply is bad, or (if you're getting two or three beeps) your memory is bad. If you get one quick beep and it shuts down, your video may be bad. How many beeps do you get?
Oct 09, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
MSI P6N Platinum not booting up
Have you plugged in the additional power supply connectors to this board at JPW1 (under the heatpipes towards the rear connector panel)? If not then you need an 8 pin 12V power supply from your PSU to this connector (This is what powers your CPU). If you don't have an 8 pin connector, you can get away with a standard 4 pin. It will only fit in one way, so you'll know.
It may sound like a daft solution, but you'd be amazed how many people forget to plug this connector in on this and similar boards.
Oct 06, 2009 | MSI P6N SLI PLATINUM Motherboard
K8 Neo-2 V-2.0
Please connect jPw1 to 4 Pin 12v, this supplies power to CPU. Than enter Bios & find Boot settings. Set the cdrom as boot 1 & hd as boot 2. Check the jumper on the cdrom, as it is the only device on secondary IDE controller it should be set as a master.
It is better to install a fresh copy of windows with a new motherboard. Put your windows CD in the cdrom & the system will boot to it. And your on your way. You can install the drivers for the board after windows has been installed.
Enjoy!
Plaease vote..
Dec 05, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
