Question about HP DesignJet 500ps InkJet Printer
I have a HP plotter 500, i am getting error code 21:10, solution?
Anybody who faced such problem
3 Suggested Answers
SOURCE: HP designjet 500 the system error 21:10
I recently had this problem as well and it was the service station gunked up with a bunch of ink over the years. Remove the right hand cover of the plotter. Remove the 2 screws that hold the service station in place and slide to the right to remove. When removed, take off the small motor by the gears. The rest is all plastic, I removed the 3 screws and "popped" the two black parts apart and cleaned the spitoon, which is just a sponge. I then dropped the thing into the sink and poured dishwasher soap. Let it sit for about an hour and rinse. It is really really messy. Then put the whole thing back together again. If I recall, the motor was the only electrical component.
Use care and caution so as NOT to break anything and I recall that the only electrical part was the small motor by the gears.
This wasn't so bad and I spent about 8 hours just because I was exercising much caution. If you're more mechanically inclined on the first go, then I would guess about 1 hr to clean and another 1 or two for dry time.
This SOLVED my problem and WOW there was a bunch of ink over the years. Don't worry, that is what the "spitoon" is used for to soak up the excess ink. Well, if not maintained or replaced, then the ink gunks the insides rock hard as in my case.
A new station is about $160 bucks. If you have HP install then you are looking at a few hundred more on top of that. To me, it was worth it and if it didn't work then I just get a new one and I had nothing to lose since the plotter was getting past the 21:10 error.
Be sure to download the HP Service Manual online so you know how to remove the service station. It is just 2 screws. Without the manual, I probably would have taken off many more screws as I would not have thought the service station simply slid out to the right. The designjet is well designed and was glad that I found a service manual online.
Good luck and use caution,
Posted on Feb 15, 2009
frankzjm
  • 191 Answers
SOURCE: I have Hp Plotter 500 and i am getting error code 21:10.
your printer error message 21:10 is about service station or carriage problem, the fix steps follow here:
http://www.computercarefiles.com/TWI_Docs/bpp90134/default.html#P16_845
hope help you fix it. take a rating let me know how much helped you thanks!
Posted on May 21, 2009
How to fix the following trouble message please thank you beforehand
This info is for technicians and explanations for the codes is limited to them
Jun 23, 2016 | HP DESIGNJET 500 InkJet Plotter Printer
Hp design jet 500 error code 5613?
System Error: 56:13
Problem
Description:
Error in the Drive Roller Encoder Sensor quadrature.
Corrective Action: Try the following:
Switch the Printer Off and wait a few minutes. Switch the Printer
On again and check if the Error Code has disappeared.
If the Error Code continues, replace the Drive Roller Encoder
sounds like the media motor encoder is dirty or has failed , there are videos on you tube on how to get to the sensor ,OR if your not up to it I would recommend Belmonte Business equipment as being much cheaper than HP to resolve your issue
Nov 29, 2012 | HP Hewlett Packard Designjet 500 42" Wide...
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
I am HP partner tech and have a problem which HP are not interested in. Fitted a new electronics module and now get 05:10 error which is bad/missing formatter, printer has never had a formatter. I press...
System Error: 05:10 Error (Only applicable to HP DesignJet 500 Series)
HP-GL/2 Accessory Card failure.
Corrective Action:
Power OFF the Printer and replace the HP-GL/2 Accessory Card
Remove the Formatter
Aug 08, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
HP DesignJet 500ps InkJet Printer Logo
698 people viewed this question
Seeker5211
Seeker5211
