Question about Lenovo Computers & Internet
Black screen with the note of power save mode
SOURCE: digital power saving mode
check your monitor power settings.
right click on your desk top then left click on 'properties' in the white box that appears.
this will bring up a 'display properties' box which should have a tab headed 'screen saver' amongst others.
select the screen saver tab.
in this tab there are 2 sections. one to select which screen saver you want to use (and what settings are applied to it), and another section which should be called 'monitor power'.
click the button here which says 'power...' to adjust your power settings.
in the next window there are 4 tabs. select the first tab (power schemes - which should be already selected by default) and you now have 4 options. leave the selected 'power scheme' in the top of the window as it is and just alter the settings for the selected power scheme.
your 4 options are: 'turn off monitor', 'turn off hard disks', 'system standby' and 'system hibernates'  i would recommend setting all of these to 'never', and don't forget to click the 'apply' button after you've done this.
i would also recommend disableing hibernation in the 'hibernate' tab (this is in the same window as the power schemes tab).
once you've adjusted your power settings, don't forget to activate one of your screen savers.  this is only important if you leave the monitor on for a long time with no changes taking place in terms of what is being displayed. if you leave a static image on for hours you will end up with permanent screen burn. (a ghost image that is always there - even when the monitor isn't switched on!).
i don't bother with screen savers personally as i find them annoying, and find it much easier to simply turn the monitor off whenever i'm not going to be using it for the next hour or more.
hope that solved your problem. apologies if it doesn't.
by the way, the tabs etc i described are what i have on my OS (windows XP pro) and may be named differently if you're using a different version of windows.  the 'power options' settings will still be accessible via 'screen saver' tab in desktop properties though.
good luck!
:o)
Posted on Oct 19, 2007
  • 40 Answers
SOURCE: screen
It is probably the ccfl inverter board that has gone out.  It is what drives the fluorescent lighting that gives your monitor a picture.  One way to test it is to shine a flashlight at an angle on the monitor while the computer is on and if you can see the picture very faintly, it is the backlighting not coming on.  It could be the bulbs, but more times than not it is the inverter.  You can usually find them on ebay along with instructions.
srich
Posted on May 23, 2008
SOURCE: Black Screen with horizontal lines
are u sure that ur not able to see the fone's stand by screen now?its totally black?are u sure that there's no problem with the screen itself,the care guys might have left the screen connection loose. other wise try one thing,Format ur fone. by pressing *#7370# u have press keys once wait for 5 seconds and press the left selectin key [where u get the YES option normally. the fone would restart and lets see are u able to go back on the screen. IF YES then u can set the Sleep mode to off cuz the sleep mode gets inititated after 20 minutes when u keep ur fone idle means u dont operate ur fone for atleast 20 minutes. BUT IN THIS CASE ULL LOSE ALL UR DATA INCLUDING CONTACTS AND MESSAGES ETC.IF U HAVENT TAKEN THE BACK UP EARLIER.so its totally upto u that u want to proceed with this step or u can again show ur fone to the nokia care guys. but they'll charge u cuz obviously after 2 years ur fone is out of warranty
Posted on Oct 05, 2008
SOURCE: dell monitor dialog box says monitor is in the power save mode
Actually, it most likely is not the monitor which is in "power save mode", it is the computer itself.
When you cannot get a computer out of "power save mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty.
Usually, this happens on a computer which is a few years old, since its batteries will have run out after such a long time. (The motherboard battery is used to store various settings when the computer power is off, such as date and time. When your computer detects this battery is empty, it goes into a low-power mode).
The solution is to replace the button-cell battery on the motherboard of your computer:
  • open the case of your computer;
  • visually locate the motherboard (the main electronic circuit board) of your computer;
  • visually scan the motherboard for a button-cell battery (it looks like a digital watch battery, but a bit larger);
  • remove this motherboard battery from your computer;
  • restart your computer: it should now power up normally (you may get some warning messages during the start-up sequence, but ignore them);
  • set the date and time of your computer using the "Date and Time" control panel;
  • you can now use your computer normally, but you will lose date and time settings when you disconnect the computer power cord, since there is no motherboard battery present to store them;
  • take the motherboard battery to an electronics store and get a replacement;
  • install the new battery in your computer;
  • restart your computer, and set the date and time again; the settings will now be saved using motherboard battery power.
Posted on Dec 07, 2008
nyilasrobert
  • 627 Answers
SOURCE: PC monitor warning error of PC entering power saving mode
it is CPU overheating problem, Go out and get some composite paste which is keeping the temp down
Posted on Jul 13, 2009
Cannot open the printer
AC driver PCB problem !
PCB needs to be replaced
Nov 10, 2013 | Xerox DocuColor 12 Printer
If i leave computer on without anyone using it . computer goes to black/dark screen , can't perform any functions. also computer crashes at times during use.
You need to check your power settings. It is being set to go to turn of the drivers after a certain amount of time.
Control Panel\Hardware and Sound\Power Options Then change the power options so it does not shut off the hard drive.
Mar 06, 2011 | Gateway DX4300-03 Desktop PC
I have a hyundai monitor which keeps switching itself off Displays the computer screen then goes into energy saving mode after a second or so Help!
alastairhaig, Is unit 4 years old? Could be problem with units switch-mode-power-supply if same thing occurs when connected to fully functioning different pc that has all screen saver and power save features disabled. After screen goes "black" do you still see the WIN-desktop screen and icon's if you hold a bright flashlight at different angles about 1 inch from the screen? SEE = power supply in "partial shutdown" mode. NO SEE = smps in "full shutdown" mode. Do some reading in my fixya profile about "black screen of death" repairs. also read FIXYA profiles of "budmrtn" "buddymc" and other fine profiles of technicians here on fixya. You will truly be amazed when you visit YOUTUBE for video clips of owners/technicians who save their cold cathode fluorescent lamp, back-lit lcd monitors from the "trash-heap"!!! After you do your research please return here and rate this response and possibly do additional comment. 12fixlouie
Oct 12, 2010 | Hyundai Electronics Hyundai N91W (Black)...
Power Save mode on, can not use computer
If your computer is indeed running, simply unplug your monitor from the wall, and then plug it back in. This will bring your monitor out of power save mode instantly.
Apr 22, 2010 | Dell Dimension 8400 PC Desktop
Our computer is on but the screen says ''power save mode'' and then will go black. How do we fix this?
You will have to wake up the computer, right click on the main windows screen, go to properties, go to display,
Then go to screensaver, then go to power options.
Now that your hear, you can change any settings, power saving mode, Battery power mode, ac power mode, what happens when you close your lid, and more.
Mar 06, 2010 | Computers & Internet
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
Black screen
exacley what it say it makes it think its in safe mode it will turn on go green then turns in to safe mode then stayes whats wrong
Dec 22, 2009 | Dell E173FP 17" LCD Monitor
When PC is not used, screen goes black, then Check Signal Cable
right click on your desktop.go to properties.in properties go to the screen saver tab.click on the screen saver tab.under the screen saver tab you will a tab called power.click on power.change you monitor settings there.let me know if it works
Sep 07, 2009 | Computers & Internet
Gateway screen stops at power saving mode
Try This
1 Start tapping F8 while poering on the PC
(Don't stop tapping until you get to the advanced boot option menu
2.With the arrow key(up & down) go to Safe Mode With Command Prompts <Enter> chose Operating System <Enter> Signin as ADMINISTRATER
Note: this should get you to a command prompt window with a blinking curser
3.In the (Black) Command prompt window type chkdsk /r <Enter>
4. you will get a message stating the valume is in use and can not be used would you like to set a chkdsk on reboot <Y> <Enter> and reboot PC
On Reboot the PC will go thru a system check. This will take several minutes.
5. after the chckdsk is complete reboot the PC you should be able to access you profile to signin
Jan 20, 2009 | Dell OptiPlex GX280 PC Desktop
Nothing appears on the LCD screen. What should I do?
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode. When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
