Question about Tools & Hardware - Others
What are die sets used for? - Tools & Hardware - Others
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
A Die set is used to make or restore threaded holes in various materials, such as steel. Sets come in Metric or Imperial sizes and pitches.
Posted on Feb 14, 2015
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 20 Answers
Die sets are used for cutting and shaping of materials. They generally use a press and a mold that are cutomized for the item they are making.
Posted on Jan 02, 2014
How do I use a tap and die set?
Its not really all that complicated, I have found the steps on this site to be very easy to follow. http://www.diynetwork.com/how-to/how-to-use-a-tap-and-die-set/index.html
Jan 02, 2014 | Tools & Hardware - Others
What is included in a die set?
A die set is a collection of equipment that can include; upper and lower die shoes, punch and die retainers, guide pins and bushings.
Jan 28, 2013 | Tools & Hardware - Others
I have a makita jn1601 nibbler and I'm trying to change the punch. How do I do this?
Removing or installing the punch and die
Always replace the punch and die as a set.
To remove the punch and die, loosen the lock nut with the wrench.
Remove the die holder from the tool.
Use the hex wrench to loosen the bolts which secure the die. Remove the die
from the die holder.
Use the hex wrench to loosen the screw which secures
the punch.
Pull the punch out of the punch holder.
To install the punch and die, insert the punch into the
punch holder so that the notch in the punch faces toward
the screw.
Tighten the screw to secure the punch.
Install the die on the die holder.
Tighten the bolts to secure the die.
Then install the die holder on the tool so that the punch is
inserted through the hole in the die holder.
Tighten the lock nut to secure the die holder.
After replacing the punch and die, lubricate them with machine oil and run
tool as needed
Here is a link to a manual in case you need it to:
http://www.makita.ca/data/upload/tools/(JN1601)883894-943_75725_owner_English.pdf
Thanks for using FIXYA
Please rate us.
May 25, 2011 | Makita Garden
Our 2001 camry lost power going down the road and died. We looked under the hood and the pulley that comes off the engine that runs the alternator belthad came apart. If the pulley came apart and that belt...
I'm not sure about the belt set up, it should be on a sticker under the hood. But losing your alt can cause the car to die due to loss of electrical power to run the computer, fuel pump, coils, ext. on some cars you can run for awhile on the battery, but eventually it'll die. Some cars are set up to die if the alt fails so that the rest of the cars systems can still be used
Apr 11, 2010 | 2001 Toyota Camry
How do I configure a Zebrazm4 Plus printer for a
Usually the easiest way to do this is to make sure the printer driver you're using is set for continous labels. This setting will vary depending on the driver / software being used to print labels. You can also go into the SETUP mode on the printer and make sure MEDIA TYPE is set to continous. Be aware that most printer drivers will override the setting in the printer. You may set to continous in the printer but if the software is set for die cut labels, then the printer will act for printing die cut labels when a format is sent to the printer.
Mar 25, 2010 | Zebra Z4Mplus Label Printer
Model rs1200 w/791 bypass hit start button runs 3 minutes then dies,starts by it self runs 3 minutes dies, starts by its self runs 3 minutes dies, use key starts & runs fine
check your documentation on adjusting the runtime for the unit. Normally they will run 15min. shutdown then restart run 15min. ect. also check the settings for use of a tach wire.
Dec 29, 2009 | Bulldog Remote Starter & T-Harness Kit for...
THE ENGINE RUNS FINE FOR 10 SECONDS THEN KIND OF DIES OUT BUT WILL THEN RUN FINE FOR 10 SECONDS AND THEN DIE OUT
Try replacing the in-line fuel filter, the Air Filter and Spark Plugs. Also make sure that you are using the proper start up procedure. In many cases that means using the highest choke setting until the engine tries to start, then going to the next choke setting and so forth until you get to no choke. It is imperative that you let engine run for at least 5 minutes before use to warm up. This will ensure a longer life and consistent running.
Oct 06, 2009 | Homelite Consumer Products Backpack...
MONARCH 9416 300DPI PRINTER
Seagull would likely have to provide the real help here, but it sounds like your Seagull drivers are not using the correct supply setting. If the supplies have a black mark on the back of the liner, then set your driver up as black mark. If they ONLY have a small gap between the labels, then set it up as die cut. If it has a die cut and a black mark, set them up as black mark.
It is also possible that your sensor is dirty, damaged, or covered up so that the printer cannot see the supplies. If you're not using Monarch/Paxar/Avery Dennison supplies, then the index mark (die cut or black mark) may not be to the printer's specification and it just doesn't know when to start and stop on a label.
Jul 24, 2009 | Monarch 9416 (Part M09416-TT04) Printer
Backup battery
The backup battery exists to protect your data when the main battery dies. It only has enough power to keep the internal memory 'alive' so you dont lose your files, settings etc.
When the backup battery dies it should be replaced as soon as possible, as the main battery will power the internal memory only while it has charge. Should the main battery die it would be like performing a hard reset.
Jun 16, 2008 | HP iPAQ hw6515 Pocket PC
Tools & Hardware - Others Logo
69 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
