Question about Vivotek Computers & Internet
Reset factory default password - Vivotek Computers & Internet
ImWireless
  • 113 Answers
SOURCE: cannot reset to factory default
Try hard reset Hold the reset button for a minute and while you are holding the button, also unplug the power cable from the back every 15 seconds. So, you would unplug the power 3 times and make sure, dont release the reset button even when the power is unplugged. This works for most of the SOHO routers. cheers
Posted on Mar 14, 2007
sandrew
  • 2961 Answers
SOURCE: Password recovery
download and install this programme, and if you have any passwords set in your pc, click 'Secrets' on the list in the left column and any passwords will appear. http://www.gtopala.com/siw-download.html
Posted on Aug 21, 2007
  • 137 Answers
SOURCE: factory set password for samsung x 160
Security Code' refers to a code aimed at preventing others from using the handsets should it be lost or stolen. The initial security code default is '0000'.
Posted on Jul 15, 2009
  • 2072 Answers
SOURCE: How do I reset a Xerox Phaser 4500 Centreware
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Posted on Mar 03, 2010
SOURCE: what is the default password for lemon mobile?
lemon duo it717
reset factory settings
Posted on Jan 25, 2011
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
I lost my password to my netgear, to hook up my second computer?
You don't need a password to hook up a second computer - just plug it in. You only need the password if you want to change the configuration of the router.If that's the case, the default user ID for this model is 'Admin' and the default password is 'password'. If you have a non-default password you will have to reset the router to factory defaults and then login with the default ID/password.
To reset to factory defaults, press and hold the Reset button until the Test LED turns on (about 10 seconds). Release the Default Reset button and wait for the router to reboot
Feb 19, 2011 | NetGear WGT624 Wireless Router
How to retrieve forgotten password
hi there,just unplug it,then plug it back in,the password should be reset...
Please Rate max...appreciate it..
Feb 01, 2011 | Cisco Linksys E2000 Advanced WirelessN...
I forgot my Password for NETGear WGT624 Please help
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Jan 17, 2011 | NetGear WGT624 Wireless Router
Default factory password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
This applies to:
  • Most of the NETGEAR devices such as routers and smart switches.
Aug 13, 2010 | Cell Phones
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
Mar 03, 2010 | Xerox Phaser 4500 Printer
Forgot the password of my belkin router
Hold the Reset Button in, (You have to use a Pen Tip) for at least 5 seconds, that should reset router back to factory defaults.
Sep 05, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Factory default
The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624. Note: If you do not remember your password, you will have to reset the router to factory defaults. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
Factory default
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
41 people viewed this question
Top Vivotek Computers & Internet Experts
U-Spy Store DBA Pro...
Level 1 Expert
Ali Karbasian
Ali Karbasian
Are you a Vivotek Computer and Internet Expert? Answer questions, earn points and help others
