Question about Ricoh Aficio Office Equipment & Supplies
They are have display in touchscreen:you do not have the privileges to use this funtion
What is the solution of this problem the display of the touchscreen is:you do not have the privileges to use this function
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
Log in with admin / no password in User Tools
Posted on Mar 03, 2014
Bizhub c6500 error code C-3913
Check the fusing position, check all connector, make sure everything oke, and doing this adjustment:
Utility => Stop => 0 => Stop => 0 => 0 => 1. This is to prevent accidental reset of the code and causing additional damage to the machine. To reset a fuser abnormality code, perform the following:
1. Power the machine OFF from the main switch leaving the sub switch ON.
2. Press the utility Key and power ON the machine from the main switch.
3. Enter Stop => 0 => 0 => Stop => 0 => 1.
4. Press [03 System Setting] on the touchscreen. 5. Press [01 Software SW setting] on the touchscreen.
6. Press the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
7. Select the bit number of switch 1, using the right up-arrow, 03-1 will be indicated.
8. Press the [Return] key, which is displayed on the touchscreen.
Dec 22, 2016 | Konica Minolta Bizhub C 6500 Copier
Supportinfo harmonyremote com
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
If the remote control is funtioning OK, visit the sites liked below to get set-up code/s list.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 14, 2014 | Logitech Harmony 1100 LCD Touchscreen...
HT-E5500 FUNTION(SOURCES) KEEPS CHANGING ON ITS OWN
Why does the HT-E5500 FUNTION(SOURCES) KEEPS CHANGING ON ITS OWN
Sep 06, 2013 | Samsung HTE5500
Garmin Nuvi 1300 touch screen not working
It sounds like you need your touchscreen replaced. The touchscreen is soldered to the LCD display, so the touchscreen must be unsoldered from the LCD display and a new touchscreen resoldered to the LCD display. Please do not attempt to do this yourself. You can easily damage the LCD display in the process. More information about touchscreen replacement can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Apr 21, 2013 | Garmin nuvi GPS
Bernina 165 touchscreen not working
It sounds like you may have two problems - one is easy, but without the other, its hard !!! If the touchscreen isn't working, it may simply be mis-calibrated and cant be accessed. To recalibrate the touchscreen from scratch, switch the machine on whilst, at the same time, pressing both of the two needle position buttons - the calibration screen should then come up and you should touch the screen where the dots are shown to recalibrate it. If, pressing the dots does not do anything, the probability is that your touch overlay or main control board is faulty, in which case you will need to take it to your Bernina agent. If you manage to re-calibrate the touchscreen OK, switch the machine off and back on again and if the display is still very grey but readable, you can adjust the contrast of the display by pressing the button with an arrow facing right, inside a box - this will take you to the user adjustment menu. Touch the display button that has a symbol with three vertical bars of different shades of grey and this will take you to a display that allows the brightness and contrast to be adjusted - touch the up or down buttons to get the best display contrast and once this is done, you should be all working again. Good Luck
Jul 02, 2012 | Sewing Machines
Mx-3000 screen display
It is not possible to get its display as sare part.
May 02, 2012 | Universal Remote Control MX-3000 LCD...
Touchscreen display elo flickering
Turn down the brightness on the monitor, if it works it will be a short term fix, the problem is in the inverter transformer or capacitors in the power supply board.
Apr 03, 2012 | Tyco Electronics ELO Parts Touchscreen...
Touchscreen locked @ enter pin. Unit won't shut off unless power
The security pin ID was designed to discourage theft of Garmin GPS products. You can change the security PIN by taking your GPS to the location where you set the PIN and or send it back to Garmin with proof of purchase. I would see if you can update your unit through Garmin web site to see if it helps with the power issue, if not, it probably is the hardware switch and will require you to send it back to Garmin. If you purchased your unit from Costco, simply return it for a new one. Membership privileges. If you purchased it from your local retailer such as Auto Nav 2000 Plus, Inc. I'm sure they can assist you with getting your issue resolve with Garmin. If you purchased it eBay or an auction site, you maybe out of luck. Good Luck
Apr 03, 2010 | Garmin nuvi 255W GPS Receiver
My tv is blank after I connect the 15 pin cable to S6240 laptop
you have to enable eigther Daul Display in display properties or Cloned display. Most laptops have a funtion key (Fn) on the keyboard and an F key (usually F4) that toggles this funtion. the F key will have a picture of a screen on it.
Aug 17, 2009 | Fujitsu LifeBook S6240 Notebook
Code F34-1 means for a Konica 7065
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
109 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
