MY KYOCERA MACHINE HAS AN ERROR CODE C 0180 - Office Equipment & Supplies
4 Suggested Answers
  • 4 Answers
SOURCE: error code is 0180
mr rupabai your problem is in the magenta starter try to intialiaze it again by pressing " 28 at the same time
copier
function
install
int m press it and wait a few minutes if an error occured after intializing change the magenta starter and intialized again
Posted on Mar 28, 2008
KingDWS
  • 1606 Answers
SOURCE: ''HP Laserjet 4600, Error code 81 0180 E10 1 Error''
That indicates that the printer has a network card problem. You can try rebooting/resetting which can clear it but usually means a trip to the hp repair shop.
Posted on Jul 09, 2009
paulvanderne
  • 48 Answers
SOURCE: Error Code C 7460 On Kyocera Taskalfa 8000i
Developer shutter locked - open front cover and slide the developer shutter to open/unlock, restart the machine. The shutter is locked to prevent developer spilling when transporting the machine.
Posted on Oct 30, 2012
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Kyocera 6525 code 180 what is the trouble this
0180 == Machine number mismatch
Machine number of main and
engine does not match.
==Data damage of
EEPROM.
contact supplier
Nov 04, 2014 | Office Equipment & Supplies
Error code c6020
you need to reset the fixing unit. go to mode and input 163 then start off then on.
Feb 28, 2014 | Kyocera Mita Office Equipment & Supplies
Kyocera 1035 machine has an error code 6030
This error code indicates that you have a fault with the fuser of the machine,
Try turning the machine off at the wall for 10 minutes.
Jan 02, 2014 | Kyocera 1035MFP Copy Machine-Printer
Kyocera error c7200
km 6030 machine have a code on screen c7200 so how i solve it
Dec 18, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
How do you correct error c 0180 in kyocera copier machines?
If reseating connectors on mainboard do not solve then:
1087 1087 get in to maint.
004 START
Choose the 003 line by touching it and activate it.
Reboot when told to.
May 10, 2012 | Kyocera Office Equipment & Supplies
Kyocera 1500 LA error E33 what need to do? i am mexican so please help me in spanish if you can thank!!!!
E 33 means that the machine is out of toner. Please replace toner the machine will be ok.
Oct 13, 2010 | Kyocera Office Equipment & Supplies
ERROR CODE C630 ON KYOCERA KM-1510
this is a fuser error meaning that the fuser has overheated. In most cases the thermal fuse or thermostat blows and will need replacing. especially if you get the 630 code, and switch the machine of and back on and get a 610 code.
Oct 13, 2008 | Kyocera KM-1510 Copier
Error code is 0180
copier
function
install
Mar 21, 2008 | Canon CLC 1120 Color Copier
79 people viewed this question
jasbo
jasbo
