Question about Whirlpool Washing Machines
Does not spin
During the washing it is sptops on spin cicle
4 Suggested Answers
  • 670 Answers
SOURCE: hello. My washer kemnore Mod. 110.29822800 NO WASH
Sounds like the timer is faulty and needs to be replaced.
Posted on Jul 17, 2010
TheMobilian
  • 8220 Answers
SOURCE: MY CABRIO WASHING MASHINE IS
You should try and remove the inner tub to see if a wire or small nail is stuck in there making all that noise.
Cabrio service manual
Posted on Jan 31, 2011
chans007
  • 66 Answers
SOURCE: The machine stop during spin
You might want to check the drive belt of your washer. There might be kinks with its belt and you should straighten it up. Also, check for signs of loose objects such as buttons and coins. These might get stuck in your washer's motor causing a malfunction in its spin cycle. Source(s): http://www.washingmachineadvisor.com
Posted on May 16, 2011
Any suggestions to washing machine which works with irregular water supply?
all models have a water level sensor in them that you set according to the wash load you have
when you turn them on the water flows until the level set switches off the inlet tap and proceeds to wash
regardless of the water pressures and delivery, the wash will not proceed until the water level setting is reached
the problem that you face is that during the rinse cycle , there may not be enough water available to rinse within the rinse/ spin cycle
Aug 14, 2016 | Indesit Washing Machines
Makes noise during wash cicles and dishes are not cleaned
Hi Kenneth Cho - I will suggest verifying that there is enough water pressure coming into the unit. Is the unit making a grinding noise? If it is, then the dishwasher seems to have a defective drain motor. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Nov 24, 2012 | Frigidaire FGHD2433KF Builtin Dishwasher
The machine stop during spin cicle
May 16, 2011 | Speed Queen Washing Machines
I have a washer machine wirpool and dasnt change to the cicle spine
If your timer goes normally until it hits the spin cycle then it is your clutch on your motor. If your timer stops during a cycle then it is timer. Either way this problem should be able to fix around $150 to $200 depending on labor costs.
Apr 15, 2011 | Washing Machines
MY WASHER IS NOT DOING THE SPIN CICLE, DRAINS ALL THE WATER OK, PUMP IS FINE, JUST DOES NOT SPIN
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | LG WFT1071TP Top Load Washer
Hello. My washer kemnore Mod. 110.29822800 NO WASH
Jul 16, 2010 | Kenmore Washing Machines
Washer stop
My first thought Lid switch gone bad. This washer has a motor which reverses. The motor is a double shaft design. 1 end of that motor drives the transmission and the other end drives the pump. When moving in one direction the tranny agitates them clothes and the water cannot be repelled out of the washer. On spin cycle the motor goes opposite directione and tosses out that water while spinning the drum. Later models have a fancy spin pawl which allows them pump to empty that water and lessen the strain on the motor. If that safety lid switch don't act right then them washer will be dead in da water during dat rinsing cycle. Now here is a wondermous vido i found on dat new fangled world wide web from repair clinic the most wondermous site to buy them parts for this washer.
More good stuff HERE
Visit my forum and I might told you a story: Here
Jun 19, 2010 | Whirlpool Inglis IP4400 Washer
Machine does not drain and spin at end of cicle It is a LG top loader washing machine model R852
Your motor clutch is bad. That controls on the motor along with the timer on a washer from going to spin or agitate.
Dec 05, 2009 | LG Washing Machines
Washing Machines Logo
100 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
