Question about Jwin JV-TV2042 5.5 in. Portable Television
It has not the C405 capacitor
Hello I bought a new JV-TV2042 system, when I plugged the cameras and connect it didn´t operate (the screen doesn´t turn on), I bougth it in a city and delivery to a 280 Km another city, I ask to the technician what happen and we can see the board has not the C405 capacitor, could you help me to know the value to insert and solder it, we think it was a assembled mistake.
For any answer please send me an email to rene_ayala@msn.com.
Thanks for your help....
Rene Ayala
  • 525 Answers
If your are a technician , you will be able to do that.
remove the back, carefully remove the main board, plug the tv. with the multimeter on DC voltage, check the voltage at that point . If you find a 10V , the capacitor will be 16V, if 12V the capacitor will be 25V. in general the capacitor have to be electrolytic and have more than 470microfard.
Posted on Aug 14, 2009
Power switch not working
hello sir .. does your batteries are charged already??
if your batteries are fully charged and your camera didn`t turn on,
there`s a possibility that your camera has a problem. You can visit the store where you bought your camera and you can ask questions there why does your camera didn`t turn on whenever your batteries are ok .. :)
Feb 23, 2013 | Kodak EasyShare C142 Digital Camera
I have a Samsung ST50. I plugged it into the computer a few weeks ago to download some pictures and a message came up saying the USB device I was using had malfunctioned and my computer didn't...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 25, 2011 | Samsung DualView TL220 Digital Camera
My camera keeps turning off and turning on, the lens open and close suddenly and nothing appears on the screen, except for a short period of time i can see the image in the screen. i have take out the...
Hi, Have you tried a different battery as it sounds like the battery may be a lemon? Also depending where you bought it you may be able to return or exchange it still.
Aug 29, 2011 | Olympus STYLUS TOUGH6020 Digital Camera
I have a new sd600 canon powershot.It doesn't have the software.Do i need software to upload pics in my pc with windows xp? I tried without the software but i didn't get any connection.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 09, 2011 | Canon PowerShot SD600 Digital Camera
Purchased Vistaquest FS-503 converter. Used two days. Screen doesn't light up and closing cover doesn't turn off the power (light continues showing through the slot for slide holder). Any easy...
take it back for exchange or a refund. A capacitor in the circuit is at fault not distributing the needed power to operate this camera
Jun 26, 2011 | VistaQuest Cameras
Error 2 in my coolpix 8800. I bought a new battery in the store they said to do that, didn't help an I changed the memory card as well, didn't help
hi your camera has system error, usually the lens unit doesn't reset after taking picture. it cause error message. you should contact to nikon service center and ask them repair cost. usually they will tell on the phone. thanks and best regard!
May 23, 2011 | Nikon Coolpix 8800 Digital Camera
Hello, I have an Optio A30 SR 10megapixel camera. When turned on everything boots normally, splash screen, then view thru lens. But after about 5 seconds it seems to go thru a normal shutdown. Tried a new...
When the camera turns on, it goes through an initialization, and if anything isn't right with the microprocessor, it shuts the camera down. If a new battery didn't help, try cleaning the battery contacts inside the camera with a qtip and alcohol, or a pencil eraser. If that doesn't help, it's probably not a power problem, but it could be a lens issue. The following blog detais the things you can try to fix it:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If none of the steps helps, the camera will have to be serviced. You can take it into a local repair shop, or contact Pentax Support. Make sure you get an estimate first, since repair can be costly.
Good luck, and hope this helps.
Apr 19, 2011 | Pentax Optio A30 Digital Camera
Hey my tv screen work for a little a while and then turn off
I just fixed one JV-TV2040 monitor that worked intermittently. Turns out the AC power adapter was bad. The wire was cracked inside the strain relief where it goes into the adapter. You can either replace the adapter with a suitable replacement or do like I did and carefully hacksaw the case open, chop out about 4 inches of bad cable, and resolder to the circuit board. I glued the repaired unit back together with silicone glue.
Feb 03, 2011 | Jwin JV-TV2042 5.5 in. Portable Television
Hi there! Rec'd a Fuji Finepix JV camera as a gift and I'll be darn if I can't figure out how to download my photos from it. Can you lend a hand pls? Many thanks!
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive just as you'd copy any other files. Or you can use any photo cataloging program.
Jan 05, 2011 | Fuji Cameras
Camra Nicon Coolpix L18 Not compatable.
The camera doesn't care what kind of computer you have. It will take pictures just fine, with or without a computer.
It's when you want to do something with the pictures that you need a computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program. Since you didn't specify the computer or its operating system, I'm afraid I can't suggest any programs.
Mar 28, 2009 | Nikon COOLPIX L18 Digital Camera
Jwin JV-TV2042 5.5 in. Portable Television Logo
105 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
William
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
