Question about Toshiba Satellite Computers & Internet
Error 10-fa-12-045d recovery failed
My question is what is the cause of engine fail safe of range rover?someone give some advice?
Search Results
    Thread: Need Help please Engine Failsafe what is it? - Range Rovers
    www.rangerovers.net/...range-rover.../35972-need-help-please-engine-fa...
    Oct 19, 2011 - 8 posts - ‎6 authors
    I still drove my car with this engine fail-safe prog because i know all ... if you fail to do these things with most range rovers, you will always be in ... Thread: Engine failsafe mode after lambda sensor change
    Aug 1, 2014
    Thread: Engine Failsafe Throttle Actuator Control Error
    Mar 20, 2014
    Thread: Engine failsafe and air susp inactive/HDC
    Oct 22, 2010
    Re: Engine failsafe prog
    Jan 16, 2009
    More results from www.rangerovers.net
    engine failsafe mode ' LandyZone - Land Rover Forum
Jan 11, 2016 | Land Rover Range Rover Cars & Trucks
What is Error Code FA on the GE fridge GN26GMDES French door model
It could be F8 AS CANNOT EVEN FIND A ERROR CODE FOR FA ? if one of the LED segments at the bottom are out. That's a failed EEPROM. Replace ERC.
Read more: http://appliancejunk.com/forums/index.php?topic=14041.0#ixzz3dj9Ns0UZ GE Profile range JS968S0K2SS error code FA
Jun 21, 2015 | GE Refrigerators
After using recovery disks for toshiba laptop satellite l305d i get error message 10-fa12-045d, please help??
Toshiba recovery error seem likely to be due to a failing/failed HDD. If your laptop is in warranty then visit Toshiba service center. Otherwise try this--------> I would like you to try checking the HDD with an error checking program from floppy or CD or with the drive removed from the laptop and tried in a USB external enclosure in another PC.
If the HDD itself is made by Toshiba (which seems likely) you would need a generic testing program since Toshiba don't provide their own HDD checking program.
HDTune can be used from another PC.
Have a nice Day
Oct 06, 2010 | ErrorExpert
Error : 10-FC12-0002 comes up during Toshiba system rocovery what does it mean and how do i fix it?
I download this from the Toshiba support site:
While running a full system recovery from the Recovery Media, the installation may fail -- and display one of the error messages listed below. Possible causes of these error conditions are listed at right. Use this list as a troubleshooting guide -- not as an absolute list of causes, as there may be others.
"An error has occurred. ERROR :10-FC10-1710" -- may be caused by a faulty hard drive.
"An error has occurred. ERROR :10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
"An error has occurred. ERROR :10-FC12-045D / 10-FC11-045D" -- may be caused by a faulty hard drive. *****
"An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
"An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
*for this error 10-FC12-045D u nid to call 1-800-457-7777 toshiba advance technical support they will send it to depot or they will recommend ASP (Authorized Service Partner)
I suppose your recovery disks could be bad. You can get another set from Toshiba. I'm also concerned about the health of the hard drive. Did you need to run recovery because the system crashed, because it may not have been an operating sysem crash but rather a hard drive crash. Have the harddrive or whole laptop checked by a reoutable repair person or check my website: www.micromendllc.com
Mar 03, 2010 | Toshiba Satellite L300D-ST3501 Notebook
What are the blinking light error codes for
the interphase between the raw drive and the usb cable is faulty or blown up.
use the raw drive from the casing to power it directly to pc it would start working
Sep 19, 2009 | LaCie F.A. Porsche (301177) Hard Drive
A c program to implement transportation problem
#include<stdio.h>
#include<conio.h>
main()
int flag=0,flag1=0;
int s[10],d[10],sn,eop=1,dm,a[10][10];
int i,j,sum=0,min,x[10][10],k,fa,fb;
clrscr();
/* Getting The Input For the Problem*/
printf("Enter the number of Supply
scanf("%d",&sn);
printf("Enter the number of Demand
scanf("%d",&dm);
printf("Enter the Supply Values
for(i=0;i<sn;i++)
scanf("%d",&s[i]);
printf("Enter the Demand Values
for(j=0;j<sn;j++)
scanf("%d",&d[j]);
printf("Enter the elements of the array
for(i=0;i<sn;i++)
for(j=0;j<dm;j++)
scanf("%d",&a[i][j]);
/* Calculation For the Transportation */
i=0;j=0;
for(i=0,j=0;i<sn,j<dm;)
if(s[i]<d[j]) // Check supply less than demand
x[i][j]=a[i][j]*s[i]; // Calculate amount * supply
d[j]=d[j]-s[i]; // Calculate demand - supply
i++; // Increment i for the deletion of the row
or
column
else if(s[i]>=d[j]) //Check the supply greater than equal to
demand
x[i][j]=a[i][j]*d[j]; // Calculate amount * demand
s[i]=s[i]-d[j]; // Calculate supply - demand
j++; // Increment j for the deletion of the row
or
column
/* The Cost Matrix is Estimated here */
printf("Given Cost Matrix is :
for(fa=0;fa<sn;fa++)
for(fb=0;fb<dm;fb++)
printf("%d ",a[fa][fb]);
printf("
/* The Allocated Cost Matrix is */
printf("Allocated Cost Matrix is
printf("%d ",x[fa][fb]);
sum=sum+x[fa][fb];
printf("
/* Transportation Cost Estimated and Sum is Printed*/
printf("The Transportation cost:%d
",sum);
getch();
Apr 08, 2009 | Computers & Internet
Error code 10-FC06-000D while using recovery cd (backup)
Error code 10 XXXXXXX is related to hardware. It is default code generated by device manager when the operating system failed to determine which specific error code to return after an error occurs.
Error code 10 error pertains mainly to hardware issues and to compatibility issues between hardware and the software.
To troubleshoot the code 10, go to control panel>system> device manager and check if any of the hardware display a yellow “!” or a red “stop”.
1). Update the hardware device driver from either Microsoft or device vendor web site.
If the device is preinstalled on the computer, visit the computer manufacturer’s website.
2). Make sure the device is enabled in the computer BIOS. You need the system documentation, if you don’t know how to do it.
3). Disable any advanced feature of the device.
4). Install the most up to date service pack and any other updates.
Oct 29, 2008 | Toshiba Satellite A205-S4617 Notebook
Error code 10-fc06-002 in toshiba a200 after running recovery disks
This is a toshiba error when running recovery discs on your machine. There are two reasons that this could occur, one would be corrupted Recovery Discs and the other is bad hardware (Hard Disk Drive).
"An error has occurred. ERROR :10-FC12-045D" -- may be caused by a faulty hard drive.
Jun 30, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Computers & Internet Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
