Question about HP Office Equipment & Supplies
How do you clean the print head of clj2600n printer?
How do you clean the print head?
  • Ramel Mayormita May 11, 2010
    what kind of cartridge your printer use???is it off carrier or on carrier???
    Sergeant:
    Champion:
  • 240 Answers
You have 2 option ...
first using the maintenance page..
and second by wiping the printhead on the wet cloth..to remove the clog on the nozzles..
Posted on May 21, 2009
How do I clean Print heads
it is one of the very sensitive part in printers so don't touch the printer head nozzels if you want to clean printer head go to tools or settings and go to clean printer head option it is the only way for clening ph safelly option.
Jun 28, 2014 | Canon PIXMA MX340 Wireless Office...
Tip
How to clean the printer heads
When it comes to printer issues, there are few things as frustrating as expecting a clearly-printed document and ending up with something that looks like a cross between a Picasso and a Rorschadt blot. If you notice that the print quality of your documents has decreased considerably or if you are bringing an old inkjet out of retirement, you need to clean the print head to ensure you?re getting the best from your printer. A dirty or clogged print head will hinder a regular flow of ink from the ink cartridge to paper. The first step is actually knowing where the print head is and what it does. As you print a document, ink droplets leave the ink cartridge through the cartridge?s nozzle and go to the print head. The print head then lays the ink on a precise point on the paper. As you print, tiny droplets of ink can get stuck around the print head opening. If these drops get time to dry, they can form a crust around the print head opening and cause it to print poorly. Clean It With Software There are a few ways to go about cleaning the print head. Potentially, the easiest way is to let your printer clean itself. Many inkjet printers will have maintenance options in the printer?s software that will actually clean your printer for you. We used a streaky Canon BJC-80 for our testing, and the driver we installed on our system for this inkjet had quite a few maintenance options. (Keep in mind that the process for cleaning your specific printer?s print head may be slightly different than what we?re describing here.) To check these out in Windows XP, click Start and then Printers And Faxes. Right-click your printer and then Printing Preferences. This displays the Canon Bubble-Jet BJC-80 Printing Preferences dialog box, which houses various layout and print-quality preferences, as well as the printer?s maintenance options. Click the Maintenance tab to view what your printer can do from a software perspective. Our printer has two cleaning modes?Cleaning and Deep Cleaning. Cleaning isn?t quite as time-consuming as the Deep Cleaning mode, but Deep Cleaning mode does a more thorough job and can resolve some issues that the normal Cleaning mode can?t. Just click the proper cleaning mode to start it and let the cleaning process run its course. You may have to do this a number of times to get the print head clean. If you don?t see a maintenance tab, it doesn?t necessarily mean your printer doesn?t have a self-cleaning function; it just means that it doesn?t use commands from your computer to do it. For instance, on the BJC-80 you can also start the cleaning process by holding down the Resume button until you hear two beeps. Check your printer?s manual for ways to clean your print head. Clean It Yourself Some software bundles that come with printers have cleaning functions that you can use to clean your print head. If the built-in cleaning functions don?t seem to do the job, there are a few ways to clean your print head manually. Some swear by isopropyl alcohol, while others believe in just plain ol? water. When used correctly, either can help your printer perform better. First, remove your ink cartridges from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. Some printers, such as many Canon models, feature removable print heads that give you easy access to the print head and its nozzle(s). Many other inkjet printers don?t have this feature, so you?ll have to do your best to work around parts in your printer. Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets; if you get isopropyl alcohol on the gaskets, it could dry them out. If you have a removable print head, remove the ink cartridge from the print head and take the print head out of your printer. Put some isopropyl alcohol or hot water into a saucer and set the printer head in the saucer. Let it soak for at least an hour. If it?s really dirty, it might be a good idea to let it soak overnight. Let it air dry, reinstall it in your computer, and run a cleaning cycle. This should get rid of any dried ink that was loosened during the soaking.
on Apr 21, 2010 | Office Equipment & Supplies
Problem with printhead please consult user guide
Use the printer's utility program to self-clean the printer. This process may need to be repeated as many as 5 to 10 times. Often this will resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning utility has not worked. The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times.
Determine from the owner's manual where the print head is located. Epson printers, for example, are usually in the printer. Many other brands place the print head in the cartridge.
Remove the cartridge. For models where the print head is in the printer, drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Place the cartridge print head in isopropyl alcohol if the hot water soak did not unclog the print head. Leave the print head covered in alcohol overnight. Use a damp paper towel to wipe off the print head area. Dry carefully. Try the self-cleaning utility again.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the print head.
Mar 01, 2011 | Office Equipment & Supplies
New ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
My printer won't print anything - only blank pages. However, both ink cartridges have ink. Please help!
If the self-cleaning cycle does not solve the problem, try turning the printer off overnight to allow the ink to soften. Turn the printer on the next day and try printing a test pattern to see whether the problem has either disappeared or become less noticeable. This ink-saving procedure can work effectively because sometimes the dried ink on the print head needs time to soften before the printer head can be cleaned completely. Try running the self-cleaning utility again one or more times.
Steps for Manually Cleaning the Printer Head
If the overnight cleaning still does not work, there may be a layer of thick ink that is blocking the holes of the printer's head. The next option is to manually clean the printer head. Follow these steps:
* Determine from the owner's manual where the print head is located.
* Remove the ink cartridge from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. NOTE: Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets, and if you get isopropyl alcohol on the gaskets it could dry them out.
* For models where the print head is in the printer, drop 7 to 10 drops of isopropyl alcohol (91% denatured isopropyl alcohol - not 'rubbing' alcohol) down the ink receptacle area where the ink actually flows from the cartridge into the head. Run a few self-cleaning utilities. If possible, allow the printer to sit a few hours or overnight and repeat the self-cleaning utility.
* If the print head is in the cartridge, soak the cartridge print head in hot water. Allow it to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
* If the hot water soak did not unclog the print head, place the cartridge printer head in isopropyl alcohol and allow it to soak overnight. Use a damp paper towel to wipe off the print head area and dry carefully. Try the self-cleaning utility again.
* If the alcohol soak did not unclog the print head in the cartridge you may need to purchase a new cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the printer head.
Jun 09, 2010 | HP DeskJet 5150 InkJet Printer
How can i clean a printer
Apr 30, 2010 | HP LaserJet P2015dn Printer
How do I clean my printer heads
Apr 08, 2010 | Epson Stylus C86 InkJet Printer
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
65 people viewed this question
Seeker5211
Seeker5211
