Question about Toys
Sky troubleshooting getting some programes not all
How do I tune my TV in the kitchen to my Sky box in another room.
Sky box stuck in Stand By on red light Sky Box Guides faq
Sky Troubleshooting faq
either you have it hooked up wrong or skybox doesnt allow 2 screen use,you may need another skybox
May 14, 2015 | Televison & Video
Tuning bush tv
Because you haven't programmed the Sky remote correctly.
Put the TV and Sky box on, and put the telly on the Sky channel. Press Interactive on the Sky remote. Choose "Program my remote" from the menu list. Follow the onscreen guide. The pages take a bit to update so be pationent
Sep 07, 2014 | Televison & Video
How do. Get volume on sky remote
for your tv?
http://help.sky.com/tv/your-sky-remote-control/program-your-sky-remote-to-control-your-tv
follow that link,follow instructions.done : )
Mar 19, 2013 | Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
My sky + playback is not working. I have been told that new software should be down loaded. Can you please tell me exactly how to do that. Thank you
This will help you out.
You can only upgrade not install new one.
http://thetechangel.com/blogberry/2009/03/how-to-troubleshoot-a-sky-hd-box-reset-and-upgrade/
http://noods.wordpress.com/2008/08/14/how-to-reset-your-sky-box/
Thank you.
Sep 20, 2010 | Sky Toys
When switiching on the TV and selecting channel 6 (s/b Sky) all I get is a blue screen to get to the sky channel the ext button has to be pressed to take it to ext2. How can I get the TV to remember the...
You must have channel 6 programed to first ext when you turn TV on it seems that it is programed on ext2 instead of ext Go to Menu then do Auto Program when you have it on ext and make sure your inputs are on first ext and not ext2
Nov 22, 2009 | Toshiba Televison & Video
What program nuber to use when setting up recording from Sky box connected to AV2?
Connect a scart lead from the sky box into av2 scart socket on you vcr,then select av2 on the vcr as your record channel
May 10, 2009 | Philips VR620CAT VCR
How to get sky on laptop
Sky as in a picture of the sky or a program called "sky"?
Sep 29, 2008 | Computers & Internet
What are all the remote codes for the citizen tv, is there a web sight
001 / 004 / 008 / 009 / 042 / 053 / 058 / 105 / 109 / 177
These are the codes for citizen models, try one till you find the one for your citizen TV.
Dec 02, 2007 | Televison & Video
Toys Logo
56 people viewed this question
Top Toys Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
