Error c0060 kyocera km 8030 error code c0060 ,whats it? please helpe .tanx
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
fsantello
  • 4 Answers
SOURCE: Error Code 2102
Change the SMTP port from 25 to 587
Posted on Aug 20, 2009
cbtmaya
  • 84 Answers
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Posted on Aug 31, 2009
My kyocera km 8030 prints with dark lines
assalamoalikum dear you chek LD UNET and clean
ld unet
Jun 30, 2015 | Kyocera Office Equipment & Supplies
How can solve km 8030 paper ground clear fault??
my dear you chek develper unit and clean unit
and grid wire change
Feb 21, 2015 | Kyocera Km-8030 With Feed, Bank, Print,...
Error c0060
C0060 does not necessarily point to a HDD. Is it possible that the wrong model main PWB or wrong main DIMM has been installed?
Jul 20, 2014 | Kyocera Km-8030 With Feed, Bank, Print,...
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
Code erreur
c610Bitmap (DIMM) problem
Sep 08, 2009 | Kyocera KM-1510 Copier
What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
Feb 12, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
225 people viewed this question
k24674
