Question about Logitech Computers & Internet
Logitech Access keyboard, number pad disabled, NumLock is ON
This started yesterday pm, hit NumLock. Eventually rebooted, thought that would fix it. Nope.
Coldcut
  • 1554 Answers
SOURCE: Number Pad not working
I would try re-seating the keyboard cable
http://www.priorityelectronics.com/images/pop_3f4800ef5205420fabcba8488924da5b.jpg
notice 2 screws at top holding the keyboard.
Posted on Feb 20, 2008
sandy_s
  • 111 Answers
SOURCE: Logitech cordless keyboard
you have your receiver close enough to your keyboard so the keyboard can pick up from it? try resetting the keyboard when the happens and checking your batteries, before resorting to reboot.
Posted on Jun 04, 2008
SOURCE: Labtec USB Number Pad for Laptops with 2 extra USB Ports
I bought this number pad and had the same problems.
I found this fix. download this from the labtec site. http://www.labtec.com/pub/techsupport/keyboards/usb_numpad_for_notebooks_1.0v.exe This worked and the number lock off changed from grey, number lock off to, yellow number lock on and back again.
This appears to be a later driver update.
Posted on Nov 15, 2008
  • 13 Answers
SOURCE: I cant use my number pad on the right side of my keyboard.
Have you tried pressing the NumLock-key?
It is located right above the key "7" on the numpad/calculator pad.
Posted on Dec 18, 2008
SOURCE: how do you disable the HP info center pop up
I had a user with the same problem using a Microsoft wireless keyboard and mouse. This is a similar setup to most Logitech wireless desktop kits, there is one wireless receiver for both devices and it has a USB connector as well as a normally unused PS/2 (it comes with an adapter for the USB so you can use this on an old computer without USB). The user went on a trip and another "helpful" user that was in his office noticed the wireless receiver's PS/2 cable unplugged and decided to plug it in for him. I'm actually amazed that it worked as well as it did but Windows didn't recognize the keyboard correctly (103 key keyboard?). All I did to solve this problem was to unplug the PS/2 conector and load the correct software for the keyboard. I also put tape and a note on the unneeded connector to prevent this from happening again.
Posted on Jun 24, 2009
My K120 Logitech is not working on the numbers side and the accents don't either
Do you have numlock disabled? Try checking the indicator on the keyboard for numlock. Hit the numlock button and see if they start working again.
Oct 10, 2013 | Logitech Computers & Internet
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
Iwant to be ablleto balance check book usig the right side calculator pad
try the combination of
Fn Key and NumLock Key (both Fn and NumLock will be of a diff colour on the Key board) and you will have the numeric key pad available
and the same function again after your work will unlock the nummeric key pad also
hope could be of help
Mar 28, 2011 | Dell 0Y3740 Keyboard
Hi, How I shall get to know whether Keyboard's capslock numlock or scrolllock hey is on or off on Logitech Cordless MK250??? I am getting big trouble in entering different capital or small character's...
if the corresponding Numlock, Capslock, Scroll lock light are ON, then it says that the corresponding functions are activated...
For example if the Numlock light is ON, then you will be able to use your number pad...
if caps lock light is ON, then you will be able to use the Capital letters...
Dec 10, 2010 | Logitech Wireless Access Duo Optical...
HOW DO i TAKE THE EEE PC KEYS FROM NUMBERS TO LETTERS?
Most likely the Number Lock is on (this is a small format keyboard and the 10 key number pad is sharing space with the letters). If this is the keyboard on the EEE, try pressing FN+Num LK. See http://support.asus.com if you need to check other keyboard issues like reinstalling the ACPI driver.
If the keyboard is one you added, you still need to find the NumLock key. Check the Logitech site if the above subject area is correct. (Just in case you need to use a Function key to force the lock to go off.)
I hope this helps.
(Look for the NumLock key to the right of the function keys or near other keys like Pause/Break)
Apr 29, 2010 | Logitech Wireless Access Duo Optical...
I can't get numlock to come on. I can't use the
Howabout the NUMLOCK key?, there may also be a setting in the bios to switch it on by default.
Mar 18, 2010 | Logitech Wireless Access Duo Optical...
My computer keyboard is typing numbers instead of letters.. any suggestions on how to fix it
This is because most notebook keyboards have a number pad incorporated into the right-hand side of the keyboard. Numbers are being typed because the NumLock is active.
To disable this function press the NumLock key (might be marked NumLock or have a symbol that looks like a calculator on it) on the keyboard (you might need to press the Fn function key and the NumLock simultaneously).
http://www.pcdoctor-guide.com/wordpress/?p=2446
Nov 25, 2009 | Compaq Presario 700 470024-192 Notebook
Dec 17, 2008 | Logitech Cordless Desktop MX3200 Laser...
Computers & Internet Logo
12 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
