Question about Sharp AR-M207 All-In-One Laser Printer
Out of service shifter motor - Sharp AR-M207 All-In-One Laser Printer
Minolta di3010
LCC Shift Failure
• The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set period of time has elapsed after the shift operation has begun (shifter is moved to the right). • The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the shift operation has begun (shifter is moved to the right). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the shift operation has begun (shifter is moved to the right). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set period of time has elapsed after the return operation has begun (shifter is moved to the left). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the return operation has begun (shifter is moved to the left). • The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the return operation has begun (shifter is moved to the left).
1 Check the connector for proper connection, and correct as necessary. 2 PC8-LCC sensor check. 3 PC11-LCC sensor check. 4 PC12-LCC sensor check. 5 Replace PWB-C1 LCC.
Sep 09, 2014 | Konica Minolta Office Equipment & Supplies
Yz450f
Hi, Anonymous don't use JB Weld it will crack and break before you get into top gear best thing is to spot weld it then just grind it off when you are ready to replace the shaft or shifter for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
How do replace the shift shaft in my 06 yz450f YZ 400 426 450
Shift Lever Shaft Yfz 450
YAMAHA YZ450F Owner Service Manual
OEM parts for Yamaha http://www.yamaha-motor.com/assets/service/manuals/2004/lit-11626-17-11_784.pdf
Jun 30, 2013 | Yamaha YZ 450 F Motorcycles
Call for service l4-11
Use simulation 3-11 to check your shifter motor. Check the connections or replace the shifter motor.
Oct 25, 2011 | Sharp AR-M207 All-In-One Laser Printer
2003 yz450f leaking crankcase oil from bottom gasket shifter side, just had the top and bottom end redone. Ran it through break in dressed it with new rims, graphics, tires, chain, and sprockets. Seems to...
Hi, Robbinsjman1 you may have a leaky shifter shaft seal for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Shifter seal leaking YZ 400 426 450
Replace Shift Shaft Oil Seal in Seconds 2 Stroke 1998 YZ125 Example
Jul 11, 2011 | 2003 Yamaha YZ 450 F
The shift arm broke and is just dangling and does not go in gear?
There is a part that is called the shifting fork. It is a pain to change. Where the shifter attaches to the shifting fork there are teeth on the shifter and the shifting fork. The shifter has a bolt through it to tighten the shifter. I would try taking the shifter off and cleaning both the shifting fork, which sticks out of the side of the motor, had teeth or knurl then a div-et then knurl. Clean it and the shifter up really good and reinstall the shifter. Tighten the bolt on the shifter really tight. If this don't fix it, then you can tack weld the shifter back on. But if you do this do it on the outside of the shifter where it can be ground back off, in case you ever have to split the case. The shifting fork goes all the way through the motor to the other side.
Sep 04, 2010 | 1991 Suzuki DR 350 S
I have a 1998 Chevy Tahoe with the service 4wd light on and cannot switch out of 4wd, can it still be driven and what could be the problem?
if its electric shift. its probly the shifter motor. start vehicle open the door listen 4 the shifter motor. 2 see if you can hear it trying 2 shift. if not thats what it is if you can hear it tryng 2 shift it mite be vacume lines
Feb 13, 2010 | 1998 Chevrolet Tahoe
SHARP AR--M207 Error L4-11
1. Main motor lock detection
2. shifter motor trouble
Jan 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
My service 4wd light comes on periodically. What causes this?
a number or things could cause this anyone of the sensors on the transfer case or a misadjusted shifter cable
Dec 22, 2008 | 2008 Chevrolet Suburban
Sharp AR-M207 All-In-One Laser Printer Logo
13 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
