Question about AEG B8871-4 Electric Single Oven
Power button broken - AEG B8871-4 Electric Single Oven
HOW DO YOU SET THE CLOCK? I CAN'T GET THE OVENS TO WORK
If the clock is showing time you may have accidently knocked the auto button this will shut off the power to both ovens until the timer times out you must press the manual button it usually has a little hand printed on it. If you do not have any lights on the clock or oven it may be due to
1. a blown fuse or tripped power supply
2.Thermal cut out tripped or failure
3.A broken live or neutral wire isolate the power before doing any continuity tests.
4. A faulty timer.
Apr 30, 2015 | Ovens Ovens
Broken stove knob
simple flame sensors at fault eg thermocouples replace bad sensors and dsi box (direct spark ignition )
Apr 01, 2014 | Ovens
Is not working
The plug is either not getting power or is broken or dirty. Test to see which. Put meter leads from a multimeter into the socket and see if you get any voltage. Turn off the power to the stove and open the back panel and after turning power back on, carefully test again with the multimeter. If no power is coming to the socket, trace the wire to see if it is connected to a power source. If it is then change the socket.
Jan 24, 2013 | Ovens
Have a bulb broken off inside socket in gas oven..cannot remove..need help
power down at the breaker or unplug the oven,then if possible you can remove the lamp cover and shell from the rear oven wall,then most lamp bases have spade terminal connections unplug these remove the whole lamp base with the broken lamp,remove the broken bulb base,then check the center power tab inside the lamp base to make sure it isn't flattened out too much,otherwise carefully bend it upwards to make sure it makes contact with the bulbs base then re-insert the terminal connections and new bulb into the opening at the rear of oven,then replace the bulb,but,do not over tighten new bulb as this leads to non operation due to heating
Jan 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
My GE Profile Advantium Microwave Oven runs (and heats) continuously. The only way to stop it from running is to open the door.
Hi
Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 27, 2011 | GE SCB2001FSS Advantium Electric Single...
My Jenn Air Model jes9750aas is beeping and has a error code F1-7. the only button on the oven panel that does anything is the cancle. and it only beeps. I tried to turn off the power and leave it off for...
From what you say, I think it is the control panel. I looked around for the right one for your model and this is the cheapest one I found online. I know it is no fun to have broken appliances! It should be an easy fix though, as simple as switching the bad one out for a good one.
Good luck and happy Saturday!
Control Panel
Jun 11, 2011 | Ovens
Amana AEW4530DDS cancel button the only button to beep or work on control panel. Time of day lights up. oven wont work . before oven went t/u had it on broil with the door open a bit. did this fry the...
A qualified technician needs to troubleshoot the unit and determine if the bubble-keypad has broken or the control board that 'controls' it. The control board would be my guess, and would also cost the most.
Mar 16, 2010 | Amana AEW4530DDS Electric Single Oven
BOTTOM IGNITOR BROKEN,REPLACED STILL WONT FIRE
you need a volt meter to check this but if you can find you safty valve you can see if power is flowing through it by disconecting the ignitor and measuring the wire that comes to the ignitor and the other one that goes to the valve. if you have power you need to replace your saftey valve.you may allso ohm check the valve.if its open its bad
Mar 06, 2010 | Kenmore Ovens
Broken oven
see if your clock has a power on button or a reset do you know who made it ge, whirlpool,etc
Jan 20, 2008 | Ovens
AEG B8871-4 Electric Single Oven Logo
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
