Question about Air Ride Management 1997-2002 Toyota Sportsvan, Pic-Nic, Ipsum Plug and Play Air Suspension Kit
My toyota ipsum is shutting down after acceleration
Shutting especially in the morning
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 136 Answers
Crook fuel or a computer problem
Posted on Jul 28, 2015
How can I fix my blue tooth keep shutting Dow and saying rad is killing the battery
rad is bad,get rid of rad especially if it is shutting dow
Jul 24, 2015 | Cell Phones
What problem could I be having on my 2001 Toyota Ipsum 2AZ engine? it fails to pick up speed when accelerator is pressed...
could be anything, you need to give a far more in depth description of the running of the engine.
When was it last serviced?
Does it run badly or is it smooth?
Does it overheat?
Does it misfire?
does it rev and then drop?
Does it switch off.
Please add more detail and repost the query
Jul 16, 2015 | Toyota Cars & Trucks
1994 jeep cherokee laredo no spark after shutting offf at home. Been starting slower and missing the first few minutes before settleing out and runs smoother in the morning. Oil i sold though is the o
No spark can be caused by a bad crank position sensor, or a bad pick-up coil inside the distributor, especially if you can't find a signal to the coil with key on. You could also test the coil, or try a known good one. There is a test procedure for the crank position sensor, but you'd have to locate a repair manual for it. I think it's just running a resistance test across two terminals of the sensor harness connector with an ohmmeter. My son's Jeep had a bad pick-up coil that shut it down, and no spark.
Once you get it running, and if still hard starting, check the fuel pressure.
Dec 09, 2012 | 1994 Jeep Grand Cherokee
Toyota 92 model no idle upon initial start up but idle when engine is warm
Engine stalling issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
May 30, 2012 | 1992 Toyota Corolla
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
I have a 1999 toyota nadia d 4 and i am having problems it tends to accelerate when i stop and sometimes it make as if its shutting down i have to accelerate to prevent that. also when i shut down...
computer going bad . check the throttle position sensor first to see if good.also check if cable linkagaes are not binding.
take to dealer and see if it is on the recall list so they can replace the computer.
Apr 02, 2011 | Toyota Cars & Trucks
Air Ride Management 1997-2002 Toyota Sportsvan, Pic-Nic, Ipsum Plug and Play Air Suspension Kit Logo
151 people viewed this question
Top Air Ride Management Air Tools & Compressors Experts
Mr R D Cochrane
Mr R D Cochrane
Andrew Taylor
Andrew Taylor
Are you an Air Ride Management Air Tool and Compressor Expert? Answer questions, earn points and help others
