Question about Pit SSR 110CC Pro Beginner Bike
Wont spark my pit bikw wont start it sparks from some where and i dont know where i have rewired all the wires up to wat they should be and it still dint work so i took the cut out switch off and it started but now wont start again it not sparking could u help me do u think it is the coil or cdi box thing
  • funi4 May 11, 2010
    Try starting it in the dark with a helper. It sounds like a short. They will be able to see the spark in the dark and give you a better place to start.
    Problem Solver:
  • 6 Answers
I think its the coil
Posted on May 25, 2009
Theres no spark and bike wont start
you will have to check lead to spark plug then lead to coil
if your not getting spark at plug it could be a number of things ingintion
or just a loose wire best of luck hope you solve it
Mar 15, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
I have a 1994 mirage i have replaced the spark plugs, wires, and distributor cap, still wont start. i am getting fuel to injectors and starter is cranking what else can i check
Check for spark; pull the plug fom the coil, place @ 1/4" from grounded metal, crank over and look for spark.
Please let me know wat you find.
Thanks,
Tom
May 18, 2010 | 1995 Mitsubishi Mirage
My pit bike 125cc wont fire up
Try unpluging the cutouts.they are usally on 2-3 places on these bikes ,brakes,also check the fuse that is on the red wire comming off the battery it will be blown or end of fuse holder will be pushed in and not touching the fuse.
Apr 13, 2010 | RTO Pit Bikes
No spark
there are 2 wires that go to the kill switch. bare them both and put a jumper between the 2 to insure insure its not a switch falure. if you get spark, get a new switch or continue with the jumper. be sure to keep the bare wires from touching metal or youll just ground it out again and it wont start
Feb 11, 2010 | Pit SSR 110CC Pro Beginner Bike
81 jeep cj7 wont start after rewiring
check this,
remove a convenient spark plug, stick it on it's wire and place where you can see it, stick you finger over the spark plug hole and have a friend crank the engine, note whether the air blast and spark are the same instant if not the distributor's out of time
Aug 30, 2009 | 1983 Jeep CJ7
I have a pit bike 125 its not starting wot so ever got good spark but still not start
If you have spark them it must be gas. eather no gas or to much gas. Put it on chock, be sure the shut off valve is in on position.Now crank it over a few times , if it wont fire. Check the plug , is it wet or dry .If its wet then it may be flooded and needs to dry out and air out the cylinder.Try starting when dry. If its dry try putting a 1/2 oz of gas into the spark plug hole. replace the plug and turn it over . This will get them to fire up. Good luck DFD
Apr 22, 2009 | RTO Pit Bikes
Car Starts but dies
Give the car a "Tune-up". Replace the spark-plugs, the spark-plug wires, and make sure the "Timing" is correct...OK
Jan 04, 2009 | 1994 Ford Thunderbird
Pit SSR 110CC Pro Beginner  Bike Logo
301 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Tim Rickards
Tim Rickards
Are you a Pit Cycling Expert? Answer questions, earn points and help others
