Question about Lexmark X75 All-In-One InkJet Printer
Printer will not print out anything
It seems that the test print comes out fine but that is where it stops..instead of pausing at 50% then start printing, it just continues on and sends out a blank sheet of paper
  • Lexmark Expert
  • 228 Answers
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached. Will the printer perform a form feed with paper loaded when the gray button is pressed?
Next, try this printer self-test by following the steps given below:
1. Turn the printer's "Power" off (metal button).
2. Press and hold the "Paper Feed" (gray) button.
3. While holding the "Paper Feed" button down turn the "Power" button on and hold both buttons until the power light comes on 5-7 seconds.
4. Release both "Power" and "Paper Feed" buttons.
5. The printer should feed a sheet of paper in and print a test page.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault. The issue may be a communication problem, or perhaps a software conflict.
However, please let us know the name and version of the operating system (Windows XP / 2K / NT, Windows Vista, Mac) that you are using on your computer. This information is important for us to troubleshoot the issue further.
Posted on May 23, 2009
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Why does my MX420 stop printing halfway?
Hi . If copies are doing fine maybe is a network or drivers issue
May 17, 2017 | Canon Pixma MX420 All-In-One Printer
Have a Zebra 105SE that prints the FEED test just fine, but will not print the PAUSE test nor will it print a bar code label from the computer. The FEED test prints vertical bar codes while the PAUSE test...
Check to see if the pause light is on also. Make sure you are using the correct printer driver. (105se)
Try in ZPL and then try in ZPLII.
Check Delimiter character 2CH
Check Format prefix 5EH
Check Control prefix 7EH
Aug 24, 2010 | Zebra 105Se Thermal Printer
Hi There How do you print a test page from the Zebra printer itself which shows print head condition etc We've used teh self test print but are lookign for somethign more detailed etc. many thanks
Printing the "PAUSE" test will print a nice black box that will show white lines or voids for any printhead elements that are not functioning. Turn the printer off, press and hold the PAUSE key while turning on the printer. After 5-6 seconds, let go of PAUSE and let the power up self test finish.
The test label will starting printing. To stop, press PAUSE. This is also usefull for seeing the "parallelism" of the printhead by looking at the lines that print at the begining of each label. Should be the same number of lines on the left as the on the right.
Easiest way to cancel the pattern is to cycle power.
Hope that helps !
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
Zebra S300 printer pauses without printing additional copies
I Use driver from Nice Labels
http://www.nicelabel.com/downloads/nicedrivers/zebra seems to work fine
Dec 05, 2008 | Zebra Stripe S300 Thermal Label Printer
My hp deskjet 5150 will not stop printing
If you are using Windows XP
1. Click start then run then type in cmd then click ok.
2. Type in NET STOP SPOOLER
After that in the lower right corner of your screen you should see a printer icon. Delete the queueu
If that still does not work Unplug the power from the printer then wait for 5 mins then restart your computer and turn it back on.
Nov 11, 2008 | HP DeskJet 5150 InkJet Printer
Bar codes appear solid back
I have problem with the same printer, the bar code is not printed, someone can help me?
Apr 09, 2008 | Zebra 105Se Thermal Printer
Printer won't print without pressing the // button
Your problem's been posted for 4 months, so you should have figured it by now. In any case, you eed to replace the toner bottle, which is empty.
May 22, 2007 | OKI B4100 Laser Printer
Lexmark X75 All-In-One InkJet Printer Logo
188 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
