Question about MSI Ms-7050 Ver:1.3 Motherboard Combo Amd Athlon 64 3500 2.2ghz Fanned Heatsink
Reset bios makes bleeping sound when switch on
PC bleeps only not booting
Count the beeps. That is your error. Googling it is the easiest way. You don't mention make, model and OS so can't suggest anything.
Aug 23, 2016 | Computers & Internet
When you turn on the ps3 the red light stay flashing
hello it sound like ylod problem thses means it's overheated you could try a reset.turn ps3 on then press and hold the standby on the front of the ps3 you will 1 bleep then 2 short bleeps after the short bleeps release the button it might reset hope it helps
regards
shaun
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
Playstation 3 turns on but no image or sound on tv. all cables are connected.
hello, i had the same trouble all i did was reset the console press and hold the standby button on the front of the ps3 you will 1 bleep then 2 short bleeps after the short bleeps release the button it should reset hope it helps
regards
shaun
Dec 25, 2010 | Sony Playstation 3 (PS3) Console
When i switch on my ps3 its turns yellow,then red and starts blinking,any help?
hello chris have you tried to reset it, press and hold the standby button on the front of the ps3 you hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset hope it works
regards
shaun
Oct 05, 2010 | Sony Playstation 3 (PS3) Console
Switch laptop on , bleeps twich and then does nothing
Two beeps - problem with RAM.
Try to reseat it or replace.
Mar 26, 2009 | HP Compaq nx6110 Notebook
Blank monitor screen
It appears that this motherboard has an on-board video port, I would recommend unplugging the video card and try using the on-board video. Make sure that when you do this, the BIOS POST screen shows, if it stops making the beeps, but still doesn't show anything, you might want to reset the BIOS (using the on-board jumper, sometimes also displayed as CMOS reset or password reset). If it still beeps, it might be the RAM, and you might want to see (if you have more than one stick of RAM) if you can try unplugging one or the other, or even switch their locations. Good Luck.
Mar 25, 2009 | ASUS Computers & Internet
My pc
When powering up, press and hold F2 key and see if you can get to the bios. If not, unit has bad display or power supply. Does the screen display anything during your tests?
Feb 24, 2008 | Computers & Internet
Wont switch on
Did you try to reset the phone.
Normal Reset (*#7780#) : Restores ini files from rom but preserves user data (photos, 3rd party apps etc)
Deep Reset (*#7370#) : This reformats completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten.
Hard reset
Press Call + 3 + * simultaneously during the bootup phase, forces the N95 to do a complete wipe of internal memory.
This will reset the phone back to 100% standard factory configuration.
Dec 20, 2007 | Nokia N95 Cellular Phone
MSI Ms-7050 Ver:1.3 Motherboard Combo Amd Athlon 64 3500 2.2ghz Fanned Heatsink Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
