Question about APC Smart-UPS 1400INET (SU1400INET) UPS System
APC SU700I NET UPS UNIT
Fault
In diagnostics test
When runtime calibration is completed UPS still discharging battery and come up with return from low battery condition why?
New battery replaced twice
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
You need to do UPS manufacturing calibration after the battery replacement. beacuse if you dont do this the UPS is till assuming that your battery is still an old one.
Posted on Aug 14, 2009
APC SURT3000XL UPS
The fault indicator means that there is a fault in the circuitry of the UPS. It could be the control board or another part of the system. (If the batteries were bad, you would see the Replace Battery light illuminate.) If the SURT3000XL is under warranty, contact APC. The standard warranty period is 2 years for repair/replacement. Note: you'll probably have to pay for the shipping of the unit. If the unit is out of warranty, replace it with a new UPS.
I hope this helps.
Nov 13, 2013 | APC Computers & Internet
APC SmartUps SU1000I NET After we hit the power (I
The possibility of changing UPS code, so its capacity is smaller, the solution must first be returned to its original settings on PC via Hyper term,
or the relay damage, or overload
Oct 19, 2013 | Computers & Internet
Apc smart ups 750xl is dead
There is a circuit breaker on the back of the unit. You can find a copy of the manual here.
Nov 28, 2012 | APC Smart-UPS 750XL ER Battery Backup,...
Inverter fault
This unit will require you to Brain dead the whole UPS.
To see if it is actually a condition that exists with the hardware or if it was just a lock condition.
Steps:
1)Power down unit completely
2)Unplug all batteries
3)Unplug from wall
4)Leave unplugged for about 5 minutes or so WITH NO POWER AT ALL.
5)Plug batteries back in
6)Plug back into wall
7) Turn unit back on
Log into console of UPS and see if the condition returns.
If it does not return your good to go.
If the error returns. You have to replace the WHOLE battery pack.
APC has told me their units are typically good for 4-6 years, after that their units cannot hold the same tolerances as they did when they were brand new.
Hope this helps.
Oct 30, 2012 | APC SURT8000XLT-1TF3 Smart-UPS RT 8000VA -...
Why do i have 0% run time and batteries are full
try to turn off and on it again and perform runtime calibration... hope this help
Mar 23, 2012 | APC BACK-UPS XS 1300VA LCD 120V...
Battery Charging Failed on APC Matrix 5KVA
you will need to replace the unit. the charging circut has failed
Dec 27, 2009 | APC Matrix-UPS 5000 UPS System
After a power outage my apc has this clicking sound. every 4 seconds or so it sounds like it clicks and then a slightly different click 4 seconds later. However, when everything is powered up it doesn't...
I found this on the APC website;
Question: What would cause a Back-UPS Pro, a Back-UPS Pro USB, a Back-UPS RS, a Back-UPS CS, a Back-UPS LS, or A Back-UPS XS to beep once every 5 seconds with no output power?
Answer: One beep every 5 seconds is an indication that the UPS has entered what is called "Low Voltage Sleepmode".
The Back-UPS product has transferred to battery power due to a low voltage condition at the wall. The Back-UPS has remained Onbattery until its runtime was totally exhausted, however, there was still enough voltage present at the wall to trickle charge the battery.
This is considered to be a normal operating state. When the voltage returns to normal the Back-UPS will wake up and restore power to the battery outlets.
Nov 02, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Password Protected for a UPS APC Silcon SL60KF
For Silcon UPS you must ask the person who install the unit if he change the password but for the defualt calibration password is 090909
Aug 07, 2009 | APC Silcon UPS System
Insufficient runtime available on agent
Try to do a runtime calibration using your powerchute software or SNMP agent. Check what is the runtime there, or check the runtime setting of your Powerchute software, maybe it set to more than the actual runtime of the UPS.
Jun 05, 2009 | APC Smart-UPS 1500VA Shipboard...
Less back up time
I found the following on APC's web-site for the APC Back-UPS, this will hopefully fix the problem:
You can also perform a manual runtime calibration. This could be done if you have changed your equipment load or battery. Stop the PowerChute software from running; disconnect the serial cable between the computer and UPS. Next unplug the UPS from the wall and let it run on battery until it reaches low battery. Once it reaches low battery plug it back into the wall outlet and let it recharge. Recharge time can take up to 4 hours.
from link: http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_faqid=2819&p_created=1048797826&p_sid=tANR-rxj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MCZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yZWNhbGlicmF0ZQ**&p_li=&p_topview=1
Mar 31, 2009 | APC Back-UPS RS 800VA UPS System
APC Smart-UPS 1400INET (SU1400INET) UPS System Logo
371 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
