Question about Cell Phones
Unlock a panasonic KX-TG6421E
Land line, handset has locked
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
SOURCE: panasonic KX-TGA236JXS gigarange phone is dial lock
panasonic KX-TGA236JXS give error dial lock
Posted on Jan 17, 2009
  • 14 Answers
SOURCE: panasonic KX-FT73 dial lock
Press the menu key twice and enter the password. If you don't know it, key in menu#9000*550 start
Posted on Feb 16, 2009
SOURCE: panasonic KX-FT71 dial lock by gobuzer
needed to reset,
press menu,#9000*550 and start,is all.
Posted on Mar 01, 2009
How to open battery opening on Panasonic KX TGA560b
Look at the back of the KX-TGA560B handset. You should see a notch. Press down firmly on the notch on the battery cover side and slide the cover towards the bottom of the handset.
This is shown on page 3 in the handset manual which is available on the product page: http://shop.panasonic.com/support-only/KX-TGA560B.html . The direct link to the manual is ftp://ftp.panasonic.com/accessory/phone_fax/om/kx-tga560_mul_om.pdf .
I hope this helps.
Sep 25, 2017 | Panasonic Lands Phones
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
Panasonic user manual free download KX TGA740
The manual for the KX-TGA740 add-on cordless handset is available from the product page: http://shop.panasonic.com/support-only/KX-TGA740B.html?supportpage=true . The direct link to the manual is ftp://ftp.panasonic.com/accessory/phone_fax/om/kx-tga740_en_om.pdf . You may find more useful information on using the handset in the manual for the base phone with which you'll pair the handset. The KX-TGA740 is compatible with the KX-TG6411, KX-TG6421, KX-TG6431, KX-TG6441 and
KX-TG7431 phone systems. To find the manual for any of these models, see http://shop.panasonic.com/support . Enter the appropriate model number in the search bar and press enter. Scroll down the page to the support section if the page doesn't come up in the correct section.
I hope this helps.
(the handset will work the same even if your handset has a different letter suffix.)
Jan 25, 2017 | Panasonic Lands Phones
I suddenly have no Caller ID name, number and announcement. I have tried the manual that came with the phone. model KX-TG7624SK 6.0 Bluetooth Talking Caller ID Panasonic. I am tired of answering "cour
Ann also check with your telephone line provider for the land line calls that the subscribed service has been activated that forwards the calling line identity to your land phone line. Could be it somehow has become lost accidentally by the phone company.
It would be worth them checking it has not fallen off your subscriber settings to eliminate it as a possible cause)
Talking Caller ID Handset Dial #162 1 on 0 is off
Base Unit caller id Dial #*162 1 on 0 is off
Guess this toggles it from 1 or 0 in the settings
Jan 27, 2015 | Panasonic KX-TG7624SK DECT 6.0 Cordless...
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
I bought a used handset for my Panasonic wireless phone system, and now it is still registered to the original base and won't communicate with my base unit. Handset is KX-TGA931T and base is KX-TG9331T. ...
They are correct - the phones are married to the original base and can only communicate with that unit since they share frequencies. Other handsets have different frequencies ans will not work
Sep 20, 2017 | Panasonic KXTGA931T Cordless Expansion...
I have telephone panasonic kx-tg6021bx i can answer but i can not call due to its writen on the scren dial lock
when it asks for unlock press 0000. it will get unlocked... othere wise without lifting the handset press *#1234
Dec 04, 2010 | Panasonic KX-TG6021 Cordless Phone
Unable unlock the phone
from the operators extn pick up handset and dial *782 and the extension no. to be unlocked.
May 14, 2009 | Panasonic KX T7436 Corded Phone KX-T7436
How to disable dial lock without password
I am using panasonic PANASONIC KX-TG2620BX and was locked by my daughter. We had it unlocked by:
press MENU
select Dial lock
Enter password 1234
Press save
Turn off Dial lock? press yes
Jan 08, 2008 | Panasonic 5.8GHz Cordless Telephone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
