Question about Gateway Computers & Internet
Boots halfway then it stops.
I reformat my hard drive but whwn it start to load the disks it freez and stops and dose nothing
    Scholar:
  • 70 Answers
That is a sign of Hard Disk Failure or bad clusters due to inproper formating
Perform this tests to ascertain your Hard disk durability
1. Turn Off the computer
2. Restart it, Press F2 to go to the BIOS at the black screen when the PC comes up displaying the manufacturers name:
3. Goto the Advanced Menu or the Menu Option that displays your Drives.
4. On the drive that has the problem, select the option that performs a hard disk test.
This would take sometime and at the end, the result of the test would tell if your Hard disk is bad.
A second option is to use a reliable hard disk partition software like partition magic to reformat and repair bad clusters and damaged sectors in your harddisk
Click here to download it and use it if the first option fails:
http://www.soft32.com/Download/free-trial/Partition_Magic/4-151-1.html
Posted on May 21, 2009
2133 hp notebook freezes at startup repair disks that came with do nothing
The DVD driver is critical to loading the operational system, did you try setting the boot order on the usb storage device, from your comments you have done that. The only other thing you can try is remove one stick of ram and power up, if no! remove the second one and replace the first piece and try again, "long shot" but worth the try. If none of these work you may have a hard drive issue, or windows files have been corrupted.
Apr 01, 2012 | HP 2133 Notebook
Boot time dose not showing hard disk
Some laptops will show the hard drive icon light up when the pc start up and then nothing. (not often but I have seen a few) If your system is not booting after a few seconds and no hard disk light flickerring on and off, you ether have a bad hard drive or the hard drive may not be properly seated to the disk connection.
As your pc boot up, go into the BIOS and make sure your system is "seeing" the disk. if it not, you may need to replace the disk. If it does see the disk, reseat the disk making sure it is fully connected the disk connector. Reboot your pc. If it does not boot, replace the disk.
Good Luck
C2Solutions
Jan 09, 2012 | Compaq Presario C700T Notebook
This hard drive was already reformatted before because of virus infection. And now I try to reformat it again because of too many errors and very slow and freezes. But during the process some files were...
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive:
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format:
hope this helps
Jul 03, 2011 | Computers & Internet
When I start it it says operating system not found, and stops loading!
When you start it up press f2 to enter bios. Go into boot configuration. Make sure the boot order is:
1. A:/ (floppy)
2. D:/ (cd drive)
3. C:/ (hard drive)
If the boot order is correct make sure your bios are registering your hard drive. If it's not then replace the hard drive. If it is then reformat and re-install the operating system.
Aug 16, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Blue Screen of Death
yeah unfortunitly you might have to reformat the entire hard drive and start from scratch
May 05, 2010 | Dell Dimension 3000 PC Desktop
I cant reformat my hard drive. (Windows XP)
Hi. There are several causes for this type of error. Either your Windows CD is corrupted, hardware is faulty (Motherboard, RAM, hard disk, video card, etc.). You may want to try to reformat your hard drive using another computer first just to isolate if your hard drive is faulty. If you can format it using another computer, try installing windows on that computer.
Aug 27, 2009 | Microsoft Windows XP Professional for PC
PS3 freezes when booted up
This sounds like your hard drive might be bad. Try pulling the hard drive out of your PS3 then turn it on and see if it will turn on. If the system turns on then i would say your hard drive definitely needs to be replaced.
May 17, 2009 | Sony PlayStation 3 40GB System
During boot up the screen stays black
i hope can help you this,
maybe the motherboard or hard disk problem,...but you may try to reformat your hard disk and install new windows.....
Mar 10, 2009 | Fujitsu AMILO Pro V1000 Notebook
Operating system wont load?
hmmm..now..that's not too good..perhaps you need to reformat that drive? or you may find that motherboard is not seeing either item?
got a backup on that disk, I hope..
Mar 09, 2008 | HP Pavilion a1140n (PX774AA) PC Desktop
Computers & Internet Logo
256 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
