Question about Panasonic Microwave Ovens
Nn st557m w
Start button not working with cooking or timer, display okay flashing exclamation mark
  • 883 Answers
SOURCE: Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
Posted on May 25, 2007
WhIzAtIt
  • 136 Answers
SOURCE: Microwave stopped working
There is a internal locking mechanisim that has 2 or more switches that is usually attached with two or more screws next to the door latch side. Crack open the micro and adjust this by shutting the door then pushing this assy toward the latches untill all the switches look like they are being pushed in fully. If this doesn't solve the problem one of the switches or possibly more are defective. Call a local appliance repair center and get a switch there called micro switches.
Posted on Sep 15, 2007
  • 140 Answers
SOURCE: Ge microwave model JVM1190WY buttons work but does not cook
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Posted on Feb 11, 2009
danforddan1
  • 192 Answers
SOURCE: Panasonic - NN-T993SF 1350 watts microwave
Sorry this is something you wont fix at home I couldent even do this one.This is a nice unit depending on the cost this one I think is worth the repair bill , Good luck DFD please rate me TK U
Posted on Apr 13, 2009
  • 400 Answers
SOURCE: fan works,light works,timer counts down when you
This is a problem associated with the magnetron. Either the power supply (transformer, diode, capacitor) or the magnetron itself. UNPLUG, remove cover, check for burn marks, a blown fuse, and test all components. Likely you have a bad magnetron (test for low resistance lead to lead, infinite either lead to ground). I found a new magnetron, removed from freight damaged oven, online for about $40. Mine is a built in which would cost $300+ to replace, so it was worth fixing. I hope this helps you.
Posted on Nov 24, 2009
Is there an internal fuse?
there is a fuse, but if this was blown nothing would work, sounds like a capacitor on the control board,just replace the board
Oct 07, 2009 | Panasonic NN-H764 Microwave Oven
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Comes on when you open door, and now it finally quit working
I think you've put up with enough hassle from this unit and should get another one. Intermittant flakey problems are hard (read expensive) to fix.
Dec 29, 2007 | Panasonic NN-S962 Microwave Oven
Timer problem
Sounds like your timer board is fried. Replace it.
Dec 19, 2007 | Panasonic NN-T774SF Microwave Oven
Stops cooking prematurely
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Nov 21, 2007 | Panasonic NN-T964SF Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
Keypad Problem?
May 25, 2007 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
