Question about Canon Office Equipment & Supplies
E002 of Fuser temperature too low canon 3050 - Canon Office Equipment & Supplies
2 Suggested Answers
  • 51 Answers
SOURCE: Fuser Error. Low Temperature
there is a small thermometer that contacts/sits very close to the metal heat roller on your fuser, chances are when removing the jam its been bent away from the roller, have a look and try and see if you can see it, not knowing this exact printer im not sure the exact position but it is usually in the middle of the roller coming from the top of the fuser housing, another thing to check is if your fuser is actually warming up atall, if you cant feel any heat then the fuser lamp that heats it up has gone bad
Posted on Nov 14, 2009
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
Tip
ERROR codes Canon 740
Canon 740 C No problem. Means that the machine is correcting the fuser film tracking. CC Drum must be changed. Could be the drum serial number is identified by the logic as being non-compatible to that particular copier. E000 Low fuser temperature E001 High fuser temperature E002 High fuser temperature E003 Erratic fuser temperature E007 Fuser film off track and will not repair itself E010 Main drive problem E030 Counter problem E064 Scan problem, or power supply E202 Scan problem E210 Lens drive problem or lens sensor E220 Exposure lamp stays on or off E240 DC controller (main board) or composite power supply E261 Zero cross problem. Power frequency or composite power supply E400 Communication problem between boards E803 24 volt problem EO Fuser problem H Fuser overheat
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 720
Canon 720 C No problem. Means that the machine is correcting the fuser film tracking. CC Drum must be changed. Could be the drum serial number is identified by the logic as being non-compatible to that particular copier. E000 Low fuser temperature E001 High fuser temperature E002 High fuser temperature E003 Erratic fuser temperature E007 Fuser film off track and will not repair itself E010 Main drive problem E030 Counter problem E064 Scan problem, or power supply E202 Scan problem E210 Lens drive problem or lens sensor E220 Exposure lamp stays on or off E240 DC controller (main board) or composite power supply E261 Zero cross problem. Power frequency or composite power supply E400 Communication problem between boards E803 24 volt problem EO Fuser problem H Fuser overheat
Printer won't print, it flashes system error E002
In Canon printers normally error E002 is fuser low temperature, probably you must change the fuser to resolve.
Feb 22, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
Tip
ERROR codes Canon 6012F
Canon 6012F C No problem. Means that the machine is correcting the fuser film tracking. CC Drum must be changed. Could be the drum serial number is identified by the logic as being non-compatible to that particular copier. E000 Low fuser temperature E001 High fuser temperature E002 High fuser temperature E003 Erratic fuser temperature E007 Fuser film off track and will not repair itself E010 Main drive problem E030 Counter problem E064 Scan problem, or power supply E202 Scan problem E210 Lens drive problem or lens sensor E220 Exposure lamp stays on or off E240 DC controller (main board) or composite power supply E261 Zero cross problem. Power frequency or composite power supply E400 Communication problem between boards E803 24 volt problem EO Fuser problem H Fuser overheat
Tip
ERROR codes Canon 3825
Canon 3825 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
on Jan 18, 2010 | Office Equipment & Supplies
The canon ir2016 j displays E003 nd i know its fixing but i can't fix it what shall i do?
ferst solved[ astrix 2 8 astrix} servise mode athore ways replase fuser elament. E000 Fuser temp low. Heat lamp, thermoswitch, thermistor, SSR E001 Fuser temperature too high or shorted thermistor E002 Fuser temperature too low E003 Fuser temperature too low E004 SSR, or lamp reg. board E010 Drive problem E022 DV unit switching problem E030 Counter not working/open E202 Scan problem. Scan sensor, scan motor E204 Scan problem. Scan sensor, scan motor
Jan 18, 2010 | Canon iR 2016i Black and White Copier
Tip
ERROR codes Canon 3325
Canon 3325 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
Tip
ERROR codes Canon 3050
Canon 3050 E000 Fuser temp low. Heat lamp, thermoswitch, thermistor, SSR E001 Fuser temperature too high or shorted thermistor E002 Fuser temperature too low E003 Fuser temperature too low E004 SSR, or lamp reg. board E010 Drive problem E022 DV unit switching problem E030 Counter not working/open E202 Scan problem. Scan sensor, scan motor E204 Scan problem. Scan sensor, scan motor E210 Lens problem. Lens sensor, lens motor E220 Exposure lamp E240 DC controller (main board) E400 RDF circuit board E401 RDF pickup motor drive E402 RDF belt motor drive E403 RDF feed drive problem E404 RDF exit motor E411 RDF sensor problem E500 Sorter board problem E510 Sorter feed motor E512 Sorter delivery motor E514 Sorter delivery motor E520 Sort stack motor E530 ******** motor E531 Stapler motor E535 ******** motor E540 Shift problem E541 Shift problem E710 DC controller E711 DC controller E712 DC controller. Document feeder board or cable
18 people viewed this question
old marine
old marine
