How to set the time on wheel clock JLR-908
Model JLR-908
How to set alarm am and pm
Scroll the time wheel to set the alarm time.
  1. Enter the alarm time manually by scrolling the hour (or minutes) field.
  2. Scroll to AM or PM to set for morning or afternoon.
Dec 02, 2015 | Audio Players & Recorders
After changing battery, how do I re-set Mercedes-Benz wall clock ?
I didn't know Mercedes Benz had a wall clock. If the clock was on the wall there should be a wheel at the back, when you turn it it will change the time, if you are talking about the clock in the car then the model and year would come in handy in answering the question
Nov 18, 2014 | Mercedes-Benz Cars & Trucks
JLR Mangoose SDD program connection problem
Reset the Land Rover Freelander 2 setting to the original condition and try again. By the way, what is the computer system you are using? The JLR Mangoose cannot work on Windows 7 system, please make sure you install it on Windows XP system.
JLR Mangoose for Jaguar and Land Rover V137
Jun 05, 2014 | 2009 Land Rover Rover Discovery
How to change the time
Press the MODE button 3 times, the hour digits blink.
2. To set hour, turn the VOLUME wheel to obtain a desired value.
Note: Make sure the hour is set so that the AM or PM indicators are displayed correctly.
3. Press the MODE button again, the minute digits blink.
4. To set minute, turn the VOLUME wheel to obtain a desired value.
Set 12/24 Hour format
5. Press the MODE button repeatedly to enter 12/24 hour format setting mode, "H12" appears and flashing.
6. To select H12 (12Hour) or H24 (24 Hour) format, rotate the VOLUME wheel.
Exit setting mode
7. To save all settings and exit the setting mode, press the SNOOZE button.
Apr 05, 2014 | Jensen Docking Digital CD Clock Radio for...
Time master tc100 wont stop punching by itself-how to fix it?
Is it printing automatically when you insert a time card or printing without a card inserted (randomly)?
The Time Master TC100 can print both manually via the print button and automatically, depending on your print method settings. If the print method is the problem, follow these steps:
  1. Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.
  2. Press Settings to choose the print method. 1 = Automatic (default setting) - The TC100 automatically prints when the time card is inserted; 2 = Manual - After inserting the time card, press the Print Button to activate printing.
  3. Press Select to confirm the Print Method chosen.
  4. Press Mode to return to normal operation mode.
To see the full instruction manual you can visit http://www.royalsupplies.com/clocks/Instruction%20Manual%20TC100%20English%20GOLD-2005.pdf
If the issue is that the time clock is randomly printing times, I would suggest either checking the mechanism that senses a card for issues or calling Royal.
Programming Information: 1-908-429-4357Royal Service Centers: 1-888-261-3888
Sep 26, 2013 | Office Equipment & Supplies
Want to chnage time on digital clock
Dear Sir!
Beside the digital clock must be 2 switches, one is for hours and the other is for minute, if it is not when the time is 12:00 take out the clock fuse and enter it again the time will be automatic 12:00.
The clock fuse is under stearing wheel.
Hope to hepled you.
Mustafa, Kabul Afghanistan
Apr 26, 2009 | 2003 Toyota Corolla
114 people viewed this question
 Grubhead
Grubhead
