Question about Panasonic Microwave Ovens
Nn st557m w
When any program set - cooking or timer unable to press start button. on display is everything and ready to go- there is an exclamation mark flashing, having turned off an unplugged still occurs
SOURCE: Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Posted on Feb 26, 2008
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Setting time on Panasonic NN-CD748B microwave
Panasonic's UK site is here and you can choose Support, then search for spares, servicers, downloads and contact info.
Posted on Jan 09, 2009
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
Power it stays at 100% want 50%
Most microwave ovens I am familiar with have adjustable power levels.
Sep 11, 2016 | Panasonic NN-H765BF 1250 Watt Microwave...
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Microwave stops after 59 seconds
Check that a "favourite" setting has not been selected. The unit may think that is the time that you want to cook. Im not sure about your model but see if there is any clear or cancel buttons to clear any pre programmed selections. If not, unplug the machine for 15 minutes to reset the controller and try it again.
Nov 25, 2013 | Electrolux Microwave Ovens
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a panasonic nn 2501, .You can set the time, hit start, the time will run , but the microwave does not run. What is up? Door safety switch? Thanks, VIC
you are setting the time on the microwave clock , your press the wrong button ,you can try just putting in the number of mins and press start, or theres cook then time and start. if helpful plz rate..
Jan 19, 2011 | Panasonic NN-S251 Microwave Oven
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Microwave Ovens Logo
14 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
