Question about ViewSonic VG700b 17" LCD Monitor
Viewsonic vg700b lcd monitor screen turned black
With no warning of a problem my monitor screen turned black like it is turned off. I checked the power and it is getting power and it's not my video card on my pc because I plugged in another monitor and it works. What could this be and is it very expensive to fix?
    Sergeant:
    Champion:
  • 225 Answers
There's an internal hardware problem in your lcd monitor - cold soldered / defective electronic part/s. I suggest to bring the unit to an authorized service center for proper diagnosis & fix the problem. best regards
Posted on May 21, 2009
Hello the speaker on my viewsonic vg700b are not working is there anyway to fix that?
Yes. It probably is, but you need to take the monitor to a specialized workshop to check the buzzers and all the speaker components. It is not a thing to do it alone at home. If you need further assistance or have further questions please leave a comment. Cheers
Aug 26, 2010 | ViewSonic VG700b 17" LCD Monitor
I have a viewsonic VG700b monitor. Everything is fine for the screen but the built in stereo speakers don't work. I'm pretty sure the wires are in the right place so can anybody help me????
First make sure that you are using the mini stereo male phome jacks on both ends, one end is connected to the Green audio line in of the monitor, the other end should be connected to the Green audio line out of the PC, also need to set the volume controls at the PC and the monitor, starting at 1/2 level. You can also verify that the monitor amplifier is wprking or not by feeding it with an MP3 player or some kind of audio source to see if you do get the sound OK.
Mar 14, 2010 | ViewSonic VG700b 17" LCD Monitor
My viewsonic has poor image display what can be done.
Change screen resolution and color settings from the 'display settings' area within the operating system.
Dec 05, 2009 | ViewSonic VG700b 17" LCD Monitor
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
SCREEN FLICKERS ALL THE TIME. HOW TO REPAIR?
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Jun 26, 2009 | ViewSonic VG700b 17" LCD Monitor
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
May 20, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
My viewsonic vg700b turns on but the screen is black
Have you found a solution?
I have the same problem
Apr 01, 2009 | ViewSonic VG700b 17" LCD Monitor
White screen on veiwsonic vg700b
Usually a completely white screen is an indication that there is no video signal being fed to the panel from the controller. For instance, if you take a working LCD monitor and just disconnect the video cable that goes to the LCD panel from the mainboard, it will turn on and off just fine, but it will light up bright white.
So, there seems to be an issue getting the video signal from your logic board to the panel. This can be caused by a bad cable, a loose connection, a bent and/or shorted pin (from plugging it in wrong), a bad logic controller chip, or a blown fuse/component on the LCD's circuit panel (PCB that runs across the top of the back of the LCD panel.)
Hope this help!
Feel free to contact me with questions, or for sales and service.
Chris
Boise LCD
(208) 891-9117
cjmclellen@msn.com
http://BoiseLCD.webs.com
Nov 15, 2008 | ViewSonic VG700b 17" LCD Monitor
Monitor Colour
for whatever reason you have lost your blue gun. it could be a matter of an adjustment or a defective component in the blue video driver. take it to have it serviced.
Jun 20, 2006 | ViewSonic VG700b 17" LCD Monitor
ViewSonic VG700b 17" LCD Monitor Logo
312 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
