Question about Dell Latitude D410 Notebook
My system does not recognize my external cdrom drive though they are of the same brand
My dell laptop doesn't seem to 'see' the dell external cdrom drive i connected to it. I tried it with another computer but still observed the same thing. please help me out.
  • 527 Answers
Sir,
It is problem with Operating system or drivers. Go to control panel, click the icon system, go to hardware tab, go to device manager, check the listing of cd/dvd drive below it something like yellow with exclamation mark. U should not install the driver. so reinstall the driver and install it
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 21, 2009
OS install - dell mini 910
When your PC starts you have a message like "Hit DEL KEY to BIOS"
if you press that key, a menu appears. Look for a Menu like "boot menu"
Them you have to change option fisrt start, to external devide or CDROM.
Aug 04, 2012 | Dell Inspiron Mini 9 Laptop
I have a Dell Latitude CSx H500T with no operating system installed,my problem is that it does not have an optical drive and an external USB drive is not recognized.How install Windows on this machine,any...
Booting from CDROM might be the easiest way to have the OS installed. If the BIOS supports booting with USB flash drive, you can use a bootable OS USB flash drive. Making one bootable USB flash drive may be a little complicated if you don't have a CD of the operating system.
http://articles.techrepublic.com.com/5100-22_11-5928902.html
http://www.bootdisk.com/pendrive.htm
Otherwise you have options of those miniSD card or PCMCIA cards with the size of your credit card which can be used as an extension of your input devices or storage devices if you can find those ports on your laptop. PCMCIA cards are developed through time and having quite a bit versions and standards. I suggest you to contact Dell to make sure that laptop support certain types of PCMCIA card.
http://www.tomshardware.com/forum/7999-2-boot-pcmcia
Jul 11, 2010 | Dell Computers & Internet
DELL INSPIRON 1525 not recognizing CDROM Drive
  1. ensure drive is recognized by the BIOS (It should be ID'd by model in BIOS
  2. If drive is seen normally in bios, then try the fixit utility in this link: http://support.microsoft.com/kb/314060
  3. See if you can boot to the drive using your Vista DVD and run a repair my computer from DVD
  4. If none of the above works, replace the drive. If system will boot to DVD, then reinstall Vista
Sep 29, 2009 | Dell Inspiron 1525 Notebook
New Dell desktop can't recognize external hard drive
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 28, 2009 | Dell Computers & Internet
CDRom is not present in Vista 32 - Shows driver not working...
Check "Computer" or My Computer and see if the drive is there. If not, reboot the system and go to the System Setup page (hit F2 on the Dell splash screen). Check if the CDROM drive is present under Drive Configuration. If not, reseat the CDROM drive. Remove it from the computer and just put it back in. If you think this is a software issue, backup all your files to a USB flash drive and do an image restore. Hit F8 several times continuously when you see the Dell Splash Screen then select Repair Your Computer. Login on the System Recovery Page. Choose Dell Factory Image Restore. This will bring your computer back to where it started.
Please rate this if this helps.
Dec 18, 2008 | Dell Inspiron 1521 Notebook
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
Dell server
1) it may just be a driver issue. look up the control panel / devices. if you see a yellow marker , then the drive is at fault . find the driver and install, then try again.
2) maybe the cdrom is dead , try change to another one.
3) if you dont have spare , plug in an external usb cdrom drive . this way , you can still do the update. many dell laptops use external usb cdrom.
Regards
David Ng
Nov 04, 2008 | Dell PowerEdge 6300 Server
Brand new Seagate Maxtor OneTouch 4 plus 750 Gb isn't recognized
jumpered wrong or its a fake drive (knockoff) but doubtful so the real diagnostics is
start run diskmgmt.msc in it you will find if drive is unalocated or not even detected. if its not detected goto run type eventvwr and check in system for errors ..
im starting to think upper and lower cdrom filters are causing usb issue. i had issues with old zip drive software causing this.
Aug 01, 2008 | Maxtor Hard Drive
Cd rw/dvd rw now working
If you know how to open your laptop, you can try seeing if the cable to the CDROM is connected properly. On startup, does your computer recognize the drive? If it's not the cable, you need a new cdrom drive.
Jan 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Reading Data CD's
Hmmm... were the cd's originally burned using that laptop? Or were they burned on a different pc?
It could be as simple as your cdrom doesnt like something about those cd's. Or it could be a flakey cdrom.
My suggestion, try reburning them to a different brand of disk using a different pc. Then see if your laptop will read them. If not, may need to replace the cdrom. Though it reads commercially manufactured cd's, if its flakey, it will have problems reading custom made cd's.
Other option, get a usb flash drive and copy those files from that cd, in a different pc, to the flash drive.
You don't need any special drivers or programs in order to copy mp3 files from a cd to your hard drive. Yet, you would need something in order to play them. Which media player does just fine.
Flakey cdrom or flakey cd's... hope this helps.
Oct 29, 2007 | Dell Latitude D600 Notebook
Dell Latitude D410 Notebook Logo
158 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
