Question about Janome Memory Craft 10000
Janome MC11000SE error
Transferring design via USB cable to sewing machine from computer
  • 6 Answers
SOURCE: Cannot get Janome 10001 to read via USB direct link from computer
here's how I do it.
1. Get the design into jef or sew format (the only kinds janome reads). You probably already knew this, but some newbies try to use pes or art files.
2. Save it onto your computer (and remember the name of the file). I have a folder in my computer labelled "embroidery files" and then have subfolders dividing up those designs - such as animals, flowers, fonts.
3. Hook your sewing machine up to the computer via the USB cable.
4. Pull up your Janome "Easy Transfer" program (it came as a CD with your machine - this is NOT the customizing software).
5. Use that program to find your embroidery file. It's not going to show sew and jef in the same file - you'll have to switch back and forth.
6. On your sewing machine, click on the bottom button (under the screen) that shows the computer to the sewing machine (the third one).
7. Now click on the computer software "write to machine" or whatever it's called (it will be on the top tool bar).
8. Your file will be written to the sewing machine's memory and organized by the embroidery hoop size (A, B, C).
9. It will stay in the sewing machine memory until you use the cable hookup to delete it (reverse of the writing).
10. The 10001 software ate lots of the resident memory in the sewing machine - you can't store as many designs in it as the 10000 would allow. That's perfectly ok, as it only takes a few moments to move designs in and out of the machine.
To be perfectly honest, I vastly prefer doing the USB cable transfer to using the memory card jammed into the card reader deal. It's easy and quick.
Posted on Dec 30, 2007
I was having the exact same problem and just a minute ago was able to fix this. If you have the original installation cd for customizer 10000 plus when you first connect your usb cable from the machine to your xp machine choose the option to install the new hardware yourself. Then point to the cd rom drive and the drivers folder, win 2000 and the file inside of that will be the driver file. As soon as you install from this file it will be successful and you will be able to see all your Janome 10001 machine files on your computer when you work with customizer 10000 plus software. Let me know how it goes.
ec
Posted on Dec 21, 2008
  • 5 Answers
SOURCE: need help with transferring designs to machine
Put the cd into your computer drive and open it. Put your usb stick into one of the ports and open it as well. You must have the emb folder on the usb stick to put the designs into. If they are not there already- turn off your sewing machine and put the stick in. Turn on the machine and go to settings, then embroidery. Find the one that says Format. and touch that one and then let it do it's thing.
Once you have the folders on the usb stick- you can highlight the design name you want from the list (cd file) and drag it to the folder on the usb stick. Alternatively... right click on the design you want to move. Select copy. Open the folder on the usb stick and right click inside it. Select Paste. The design should appear in the folder for the usb and then you can take it out of your computer... put it into the machine and find the design.
If I can help with anything else... lmk.
Tracy in Nashville, TN
Posted on Jan 04, 2009
  • 8 Answers
SOURCE: saving designs
It is possible, if you have not virus on you flesh. Machine don't understand virus. On your flesh there is folder by name EMB. You can find your files there.
Posted on Jan 11, 2009
  • 21 Answers
SOURCE: I have the 10000 with the upgrade and am using my
If you have the customiser software open the disk up to view the drivers the driver may work with the win 2000 if so it will look for JSMC and install it. If this does not work try right clicking on the customiser icon and see if you can run in compatibility mode, Otherwise you may have to use a SD card and only transfer to that.
Posted on Oct 20, 2009
I have just purchased an old Janome Memory Craft 10001 embroidery machine and need the drivers in order to be able to connect it to my pc via usb cable.
You can go the the Janome web site to find drivers for your computer. When you save designs to the memory card you must save them in a folder (emb, i think}.Put a blank card in the machine while the machine is off anf=d then turn the machine on,,,It will make the folder for you.
Good Luck
Mar 29, 2018 | Janome Sewing Machines
I bought a janome 300e .ive purchased designs and have downloaded to my computer. I've transferred them to a disk. . On the computer it says that the designs were transferred.
Check that the designs are not in a folder on the disk. Your sewing machine may need to open that folder before the designs can be found.
Also, check to make sure the OS software on your computer is compatible with your sewing machine. Some sewing machines use Windows 7 or even earlier versions, whereas most new computers now have Windows 8 or 10.
Feb 09, 2017 | Janome Sewing Machines
Need help using flash stick to download embroidery designs from computer and what they are jef, emb,
.Jef and .Dst will work on a Janome machine. You can buy designs per the hoop sizes for your machine. Buy, download, and transfer received file to a USB drive to transfer deign to machine.
Cheers,
Embroidery Services
San Diego, CA
May 28, 2016 | Janome Memory Craft 9000 Computerized...
Transfer designs to my blank memory card
You need a a Reader/Writer box with a blank Janome memory card (PCMCIA) and Cusomizer software. With that you can move your downloaded .sew designs into Customizer and on to the card via the Reader/Writer box provied that they are within the allowable size constraints.
Jul 19, 2009 | Janome Memory Craft 9000 Computerized...
Need help with transferring designs to machine
Jan 03, 2009 | Janome Sewing Machines
Downloading embroidary designs for the Janome MC 350E
Firstly, format your compact flash card on your embroidery machine. This is presuming you have embroidery files in your jef format your machine reads on your computer. Place your compact flash in the compact flash card reader writer connected to your computer, open the compact flash card in your computer, open the file emb5. Now you can simply copy and paste a design from your computer to your flash card. It works for me. Goodluck.
Sep 20, 2008 | Janome Memory Craft 9000 Computerized...
You need to have Customizer og Digitizer pro to send design by cable to you MC10001.
You can also use a PCMCIA adapter in your MC10001 and a CF memorycard..you also need a memorycard reader to write to your CF card from your computer
Dec 28, 2007 | Janome Memory Craft 10000
Janome MC 10000 with Easy Transfer using jef files
Your internal memory files could be full and need some designs deleted, the monogram design might not be centred in the hoop so it registers outside the sewing field, The hoop selected might be too small for the design.
Dec 21, 2007 | Janome Memory Craft 10000
here's how I do it.
Oct 30, 2007 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
26 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
