Kodak go aiosupport
My kodak ESP Office 2170 printer says theres a "paper jam" or "out of paper". but there is no such physical problem with the above mentioned. when printing the rollers spin but they do not pick up the paper. what could be the problem?
    Scholar:
  • 102 Answers
1. It could be a problem with the paper sensor ( a micro switch).
2. The tray holding the paper may have a defective spring causing the paper to not contact the rollers.
In the case of a "paper jam", there may be a label or just a piece of paper with some adhesive stuck in the path of the paper inside.
If the printer has a bypass tray, run a thick piece of card stock through the printer. You might be able to use a flashlight to inspect the paper path to detect any foreign material causing the "jam sensor to come on".
Be sure to use check the printer through the control panel...open the printers and select the printer properties using the right-click of the mouse and cancel all pending print jobs....
Restart the computer.
See if that helps....
Posted on Jan 02, 2014
  • 295 Answers
SOURCE: kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Posted on Jul 28, 2009
  • 13433 Answers
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
SOURCE: Paper jam in a Kodak ESP- Printer
i had the printer jam issue when there wasnt a real printer jam.
if you push the print cartidges off to the right, then reach in and push down on the cleaning head that is located on the left on the inside, it pops back down into place and voila, printer jam error message fixed.
Posted on Jul 04, 2009
  • 295 Answers
SOURCE: paper jam message on esp 7 kodak printer
open rear access door and check out if there is any tape in and around the rollers or any torn paper or any staples there.. turn printer upside down and oprn bottom p[aper tray check out if there is any paper stuck there. take power cord out of printer and again insert it back. ur printer will work fine
  • 7 Answers
SOURCE: Printer Jam. We have a Kodak Esp 5200 Series.
Try removing the gray cover on the back of the printer to remove the paper.
Posted on Feb 11, 2010
Kodak esp 2170 carriage jam problems
The carriage operation is not synchronized. It will have to be adjusted to normal
Aug 14, 2016 | Kodak ESP Office 2170 All-in-One Printer
ESP office 2170 will print from computer, but will not copy from glass or auto feed
Try unplugging.the power cord for a couple of minutes then plug it back in you after doing that you may need to reconnect it to the internet. This will clear out junk from the printer. Then try printing. This works most of the time
Aug 14, 2015 | Kodak ESP Office 2170 All-in-One Printer
How can I clear a paper jam on Kodak all in one printer?
www.kodak.com/go/aiosupport
Getting help on the Web
For more troubleshooting information:
Paper jam
• Check for paper in the rear-access cleanout area.
• Open the printer access door and gently remove any paper from inside the printer.
• Make sure the paper in the tray is free of tears or creases.
• Make sure you do not overload the paper tray.
For more information, go to
www.kodak.com/go/stepbystep
Jan 03, 2015 | Kodak ESP Office Equipment & Supplies
How to remove print head on a Kodak ESP 5250
If the ink cartridges and printhead are already in the printer, remove them, then reinstall them.
  1. Remove the color and black ink cartridges.
  2. Remove the existing printhead by lifting the latch in the center of the carriage. printhead_removal.jpg p342_0064aa.jpg ESP 3, 5, 7, 9, 3250, 5250, 5210,
    ESP Office 6150, 7250, 9250;
    HERO 7.1, 9.1, OFFICE HERO 6.1 ESP 1.2, 3.2, 3.2s, C110, C310, C315,
    ESP Office 2150, 2170;
    HERO 3.1, 5.1
  3. Close the printer access door.
Oct 21, 2014 | Office Equipment & Supplies
Kodak ESP Office 2170 Paper Jam code 3524
Actually, to fix it, you need to disassemble the printer.
The smallest part inside the printer can trigger this error code. The printer needs to be taken apart, clean, check the paper feeder that it's not crooked or missing a piece.
I recommend that you take it to a profesional, because if you do it yourself, you need to have a bottle of crazy glue, in case something breaks, that's how we fix it.
May 16, 2017 | Kodak ESP Office 2170 All-in-One Printer
Kodak 2170 wont print black ink
how to make Kodak ESP 2170 print without color ink?
Mar 22, 2012 | Kodak ESP 2170 All-In-One InkJet Printer
k24674
jasbo
jasbo
