Question about Dehumidifiers
Delonghi troubleshooting I have had this espresso machine a couple of years, and it has now started dripping the coffee out really slowly making it weak, and no froth
Hi, my friend gave me a delonghi 5 cup k mix coffee maker. the water starts to heat you a hear a gurgle a little water is filtered to the pot and then nothing it just stops working. any ideas on how to trouble shoot?
Posted on Dec 04, 2015
How do I fix the water pump of a delonghi BC4264B? It's not pumping any water to make espresso. the machine heats up well, the steamer works fine, the drip brew side works fine. I'm not getting any...
Is there any water coming out of the group head when the porta filter is not used???the group head has a filter on it and it could be totally clogged
Jun 11, 2014 | DeLonghi DE500P Dehumidifier
Delonghi Dem 10 dehumidifier has stopped working - the 'operational light' turns on, but the fan does not start up so nothing happens.
It could be that the fan / fan motor has seized or jammed. Have a look through the vents and see if you can spin the fan. If not, you will need to strip the machine. Try lubricating the bushes / bearings. Often on these type of units, the vapours dry out the bushes and then they get tight and jam the fan.
Nov 08, 2013 | DeLonghi Dehumidifiers
De500 pump failure
I agree with Mike Kolbay's earlier very complete answer. The water intake to the pump is quite narrow, and clogs easily with accumulated lint and bacterial muck. While the covers are off the machine, thoroughly clean the drip tray and all the water passages. A piece of crud the size of your smallest fingernail can cause water to overflow onto the floor, rather than going into the tank.
Sep 06, 2012 | DeLonghi DE500 Dehumidifier
Tasciugo dehumidifer about 10 years old has started to leak. I have cleaned filter and spout water drips from is there anything else I should do. ?
Drips from where?
Find the source of the drip and seal it with rubber or waterproof tape.
If there is no pressure at the leak, this should cure it.
If you have trouble locating the leak, dry off everything and operate the
dehumidifier while you watch for the appearance of the moisture. Where
it first appears is probably the leaking location.
Aug 29, 2011 | DeLonghi Dehumidifiers
I have a De Longhi 8C70 Dehunidifyer. It is approximately seven years old. The pump is broken, when I flip the pump switch to the on position, the water no longer goes through the tube but drips into the...
Think the problem is with a clogged tube running to the drain, rather than a faulty pump.
To test this theory, first turn the unit OFF & unplug it. Using an 18" long, appropriately sized, plastic Zip Tie. Carefully insert it into the drain hole tubing and continue to push it in unitil you reach a bend in the tubing. Gingerly work it past this bend until the Zip Tie bottoms out or your run out of usable Zip Tie. Then slowly pull it back out while rotating (twisting) it. This will help break up any clogs. As you reach the tip of the Zip Tie, be prepared as some water may follow. Plug the unit back in and turn the unit ON. Set the control to Pump Mode and monitor the drain for water flow.
I hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | DeLonghi DN40G Dehumidifier
Leaking on the floor
This can be caused by two things: The bucket is not inserted properly or the drain hole or tube inside the unit is clogged and needs to be unclogged.
When removing and reinstalling the bucket, make sure that it fits into the bucket holder "squarely" from top to bottom. When installed properly, the bottom of the bucket should not tilt downward at all.
To unclogged the drain hole or tube: Turn the Master ON/OFF Switch to OFF and unplug the unit.
Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though) that is appropriately sized to fit into the drain hole or tube. Carefully insert the Zip Tie and work it in slowly. You will reach a bend in the tubing and you will gingerly, have to work it past this bend. When the Zip Tie either bottoms out or you run out of usable Zip Tie, slowly remove it while rotating (twisting) the Zip Tie. This will dislodge any clogs. Once you near the inserted end of the Zip Tie, be prepared for some water to follow.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | DeLonghi DE400 Dehumidifier
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
My dehimidifier is not draining thrrough the hose
Run a straightened coat hanger through hose or try to blow through. Or connect to faucet to clean out clog.
Make sure drip pan is clean & level. Basically vacuum any dust from inside drain area.
Apr 14, 2010 | DeLonghi DE500 Dehumidifier
Problem
Is your pump hose connected tightly?
Jul 20, 2008 | DeLonghi DE500P Dehumidifier
Dehumidifiers Logo
631 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
