Question about Kitchen Ranges
My Defy 621 electrical stove oven won't heat up
I switch on the stove to heat up and the stove light and the warmer light comes on but it does not heat up.
  • 4 Answers
There's probably a faulty connection somewhere. I had that happen a while back when I was in Dyer, IN. I looked for anything that was out of place, but I'm not as smart as I thought I was and had to hire someone (http://www.dbhappliance.com). My advice: call someone. Sorry if that wasn't much help.
Posted on Jan 16, 2014
4 Suggested Answers
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
SOURCE: GE Profile Electric Stove, no heat, looks like it needs a reset
my oven doesent work and my key pad is locked
Posted on Sep 05, 2009
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
Wiring Diagram Defy 521 Electric Stove
NEED A WIRING DIAGRAM OF A DEFY 521 ELECTRICAL STOVE
Sep 29, 2012 | Kitchen Ranges
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
Aug 02, 2011 | Stoves 720EF Electric Double Oven
My Defy 621 stove causes the earth leakage to trip after a few minutes when the oven is swithed on. The thermostat was resently replaced. Could it be one of the elements, although it seems they are...
Most likely an element. When the heating wire expands inside the tube it contacts earth and kicks out the earth leakage. Select 'grill' and try the oven. If it does not trip out the lower element is the culprit. Replacement is easy for a reasonably adept handyman - just make sure that the mains are off!
Jan 16, 2011 | Ovens
Oven not working
I had the same problem. At the back of the stove is a plastic cover with thermal overload written on it.
Switch off your power.Remove the cover, pull out the two luggs and connect the two luggs straight to each other. Make sure the oven knobbs are in the off position. turn on the power. If your oven clock etc. comes on the thermal overload is faulty and needs to be replaced. It is fixed to the stove by a screw from the inside of the oven, so open the door and remove screw to remove thermal overload at the back of oven. Take sample to electrical shop and replace. DO NOT USE OVEN WITHOUT THERMAL OVERLOAD.
Dec 27, 2008 | Ovens
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Kitchen Ranges Logo
219 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
