Question about Kitchen Ranges
Defy 621 oven does not want to get hot - Kitchen Ranges
2 Suggested Answers
  • 12962 Answers
SOURCE: My defy kitchenaire 621 stove got wet ,nw if I put it on it trips my power supply. What do I do ?
Let it dry out thoroughly and see what happens, If you have a portable heater throw that in there for a few hours to completely dry unit out. Cross your fingers and see what happens.
Pssst - water and electricity do not mix well.
Posted on Sep 07, 2015
Defy slimline eyelevel oven installed in cupboard.
Assuming it is an electric built in or built under oven, these are commonly fitted into a dedicated cupboard (oven housing) that matches the other kitchen units and typically little or no facility for ventilation is provided.
Electric ovens are usually so well insulated and covered with reflective foil the need for ventilation is minimal, especially when a standard size oven is fitted into the correct standard sized housing as it will provide an air-space of an inch or more all around.
It can be expected the housing near the top of the oven will become warm after a while and the shelf above likely to become warm enough to soften a candle but if it gets hot enough to actually melt a candle I think that is rather too hot. The addition of additional insulation and reflective material should improve matters greatly.
I suggest you approach the guy who fitted the oven if it was professionally fitted. It would have been his responsibility to only fit a suitable appliance and if additional ventilation was required he should have advised you.
I believe I have seen some oven housings with a slim grille over the oven and it is probable there would have also been a slot cut at the rear and perhaps a short piece of trunking to carry warm air away from the space directly above the oven.
Mar 30, 2016 | Ovens
Thermofan of a defy 731T that keep on burning .
check that the motor shaft is free running as the front bearing could be seizing from oven heat
if it is good , replace the fan motor
Dec 09, 2015 | Ovens
Sep 07, 2015 | Kitchen Ranges
My Defy 621 electrical stove oven won't heat up
There's probably a faulty connection somewhere. I had that happen a while back when I was in Dyer, IN. I looked for anything that was out of place, but I'm not as smart as I thought I was and had to hire someone (http://www.dbhappliance.com). My advice: call someone. Sorry if that wasn't much help.
Jan 02, 2014 | Kitchen Ranges
I have a new Defy hob with the colour connections in 4's, but my oven is an older DEFY and has two rows of 6 connectors... please help. How do I connect a new DEFY hob to an old Defy oven?
I have the same predicament. Did you manage to connect your new hob to your old stove? If so, please let us know how to do it.
Thanks.
Mar 04, 2011 | Ovens
My Defy 621 stove causes the earth leakage to trip after a few minutes when the oven is swithed on. The thermostat was resently replaced. Could it be one of the elements, although it seems they are...
Most likely an element. When the heating wire expands inside the tube it contacts earth and kicks out the earth leakage. Select 'grill' and try the oven. If it does not trip out the lower element is the culprit. Replacement is easy for a reasonably adept handyman - just make sure that the mains are off!
Jan 16, 2011 | Ovens
I have a defy gemini petit chef multi function themofan oven but dont have a manual on how to use would you be kind enough to let me no how to us it thanks naaz
i have a defy gemini petit chef thermo fan oven.I only used it for about 20 times the warranty is over the fan works but the elements are not getting hot both the grill and bake.could you please tell me what the problem could be
Apr 01, 2009 | Ovens
Kitchen Ranges Logo
13 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
