Question about Nixon 51 30 Pu Watch
24 mm watch band replacement
Where does one find a 24 mm watch band replacement for a Nixon 51-30 PU watch?
SOURCE: Nixon Watch band
I tried the hammer plyer thing way back but took a bunch of time and stress, then I took it into a skate shop where they sold nixon watches and they had an actual tool supplied by nixon and all the **** needed to do the job.
Posted on Nov 27, 2008
escapement
  • 2334 Answers
SOURCE: tighten wristband of the Nixon Watch , remove links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 05, 2009
SOURCE: I have a nixon 51-30 stainless band. Where can I
Try watchworks, i was able to get a rubber black band for my 51-30
Posted on Apr 25, 2010
Ironfist109
  • 3018 Answers
SOURCE: Where can I find a
  • For it to be an authentic Nixon Esquire Band you need get a new band from the manufacturer by calling 1-888-455-9200 or by calling or by contacting them at their repair center. For this you will need to send your watch to them -
http://www.nixonnow.com/repair-center/
  • They use a fine leather for their bands. To purchase an "authentic" band from anywhere else could mean being a victim of a counterfeit product. Now if you just want a nice leather band to put on the watch yourself then I would get one offline and get one. Here are a few site to choose from.
http://www.amazon.com/Genuine-Italian-Leather-Watchband-Black/dp/B001VE5IM4/ref=sr_1_14?s=watches&ie=UTF8&qid=1303886270&sr=1-14
http://www.thewatchprince.com/
http://www.watchbandworld.com/
Regards, Tony
Posted on Apr 27, 2011
SOURCE: nixon 51-30 screw that hold the band onto the case
The same thing happened to mine and all I need is the screw..those assholes should fix the problem at Nixon and atleast send us the screw if we're willin to pay for it..
This will b the last Nixon I buy..
Posted on Aug 01, 2011
COULD YOU HELP ME PLEASE
You should take the watch to a local jeweler / watch repair shop in your area that deals with that brand. If not, contact Nixon by this link-
http://online.nixon.com/us/en/repair-center
Aug 23, 2016 | Nixon Watches Mens The Graduate SS Watch...
User manual for nixon delta pu watch
Here you go,
http://www.nixon.com/manuals/nixon_delta.pdf
Apr 07, 2012 | Nixon Delta II stainless steel PU Digital...
Manual for nixon simplify 51-30
The manual you are needing is here.
http://www.nixon.com/mens/watches/the-51-30-tide-a057.html
Apr 02, 2012 | Nixon 51 30 Pu Watch
I change the battery of my nixon superhero TI/PU and now i cant see the digital numbers what can i do??
you need to restart digital part of the watch. Open it ( the screws part) and there you will find 2 reset contacts. You need toen close the contacts with the big battery in it. Then it should start working. This acion have helped me few hours ago.
Jun 19, 2010 | Nixon Super Hero Ss Ii Black Watch
I need a new watch band for my Nixon Scout watch
Try contacting a Nixon service center.
You can locate your nearest service center by going to their web site "www.nixonnow.com/dealers/" and filling in your details.
Mar 02, 2010 | Watches
Add link to the wrist band on my Nixon "The Player" watch?
you can find a exper in you real life or in the watch shop..
Dec 28, 2009 | Nixon Player NIX0003 Wrist Watch
Nixon 51 30 Pu Watch Logo
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
