Question about Janome Sewing Machines
Usha Jenome - thread breaks indiscriminately not able to stitch continuesly.
SOURCE: New Home sewing machine instruction manual 2039 (Jenome)
I will quit being lazy and find my manuel today...... i thought I could save time and look online. No such luck. If you have an email address I will send of fax or mail to you. I feel bad for everyone looking for it. So I will check in a few days to see if you still need it.
Lisa
Posted on Jan 08, 2008
SewTechWayne
  • 186 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Posted on Jan 31, 2009
  • 4 Answers
SOURCE: My lowerlooper thread keeps breaking. I can only
The lowerloop thread kept getting cut by the upperlooper.....I rethreaded the machine in order and then made sure that the lowerlooper thread was UNDER the part of the machine that makes the looks the loopings (silver part that comes to a point on the right side of the needles...sorry I don't know what to call it) and the upperloop was ON TOP of the same part.....it started working great. I actually have very nice tight stitches now.
Posted on Jun 20, 2009
WonderTech
  • 268 Answers
SOURCE: skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Posted on Mar 23, 2010
chrismyers67
  • 53 Answers
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Posted on Jun 07, 2010
My Usha janome allure machine is not giving stitches. And the thread curdles below.
bottom tension is not correct take bobbin out and rethread it HOLD both upper and lower threads tight . when first starting to sew
Feb 09, 2015 | Janome Sewing Machines
I have Usha allure,sometimes it gives skipped stitch,and sometimes it gives bunches at the bottom. If I use thin thread for interlock, it dosnt accept, what is the solution?
Sounds most likely to be either thread tension issue - check bobbin tension OR dull / bent needle - put a new needle in suitable for fabric being sewn. Use good quality thread.
Oct 13, 2013 | Sewing Machines
How to do darning with allure usha sewing Machine
I do not know what machine make and model this is.
But I darn the following way.
Iron onto the back of the hole/rip a piece of iron on mender in a similar colour and weight to your garment, allow just a centimetre extra around the rip. Try to bring the edges as close together and neatly as possible before ironing to attach the patch behind.
Now set the machine to a three step zig zag stitch, stitch width to the maximum and turn stitch length down to about .8 or so. Now sew over the rip/tear area fillling in the damaged area reversing back and forwards to cover the damage and a good margin around it. I use a colour matched thread if I can to make the stitching less obvious.
Done!
Mar 05, 2011 | Sewing Machines
I have one usha ordinary machine,the upper part of the machine is not rotating,it takes too strength on the stand,i cant stich,wat i do?
stitch is not coimg properly on thick places like bottom parts and thread is cutting in thick cloth place,what to do
Feb 02, 2010 | Sewing Machines
The machine pulls the cloth while stitching
Probably your needle and bobbin thread tensions are too tight. Cotton thread breaks easily under tension. Use less pressure on the presser bar and a smaller stitch length may help.
Aug 20, 2009 | Brother Sewing Machines
Usha wonder stitch motor speed very slow ,asked to replace motor
I think try some good quality lubricant first..
here you can find usha sewing machine details...
Aug 13, 2009 | Janome 6019QC Mechanical Sewing Machine
Stops Functioning
I had the same problem with my jenome, it looks that the motor belt of your machine needs to change. This was the case with my machine.
Dec 29, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
