Question about AEG 24 in. Favorit 80800 Free-standing Dishwasher
FO fault hi have an AEG dishwasher 8080-w pnc 911232069 showes FO at end of cycle any idear of what it could be it dose have a more than normal amount of water in the bottom when it finishes
3 Suggested Answers
heralddriver
SOURCE: DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Posted on Oct 25, 2008
Daniel S
  • 4323 Answers
SOURCE: We understand that your problem is: My AEG
Hi
The issue is either with a bad door lock-switch assembly or the timer/control has gone bad. Though I believe as the unit starts however, stops in middle of cycle it is the timer that should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 20, 2011
I have a AEG Favorit 65011 VI (dishwasher) which stops in the middle of a programm an shows error ",60" that is not mentioned in the Users Manual. Can you please help me?
The temperature must increase by a certain amount at each step.
If there is no temperature increase during three minutes, the electronics will generate "Heating Time Out" or fault code i60.
In this case program will continue to the end without heating and the washing result will probably be unsatisfactory.
Could be: Heating element faulty; intervention of safety
thermostats (open); faulty wiring; NTC sensor (poor
thermal contact); insufficient water circulating in the
tub; washing faulty pump (impeller stripped); circuit
board faulty.
Dado
Mar 10, 2015 | AEG Dishwashers
I have a AEG F88060VIOP dishwasher - showing error coded ,00 and beeping. Not listed in manual - can anyone help id cause and fix please? Thanks
Fault code "i00" means "Low mains voltage"
The electronic board makes sure the dishwasher operates within certain voltage limits. If during a cycle the voltage drops below the lowest limit, the electronic board suspends all loads and interrupts the cycle under way. The "i00" alarm is then triggered. The lowest main voltage threshold is 180 Volt. If the voltage goes back to over 186 Volt, the electronic board cancels the error status and the cycle
resumes. The "i00" alarm is also deleted.
If the mains voltage continues to exceed the maximum threshold, the electronic board does not do anything.
My suggestion is to call your local electrician to check the voltage in your home.
Dado
Feb 23, 2015 | AEG Dishwashers
How do I fix problem F3 and spray arm faulty on my KO FAVORIT 8080
F3 - The anti-flood protection system has activated.
When in operation the fault message F3 appears in multi dispay:
  • First close the water tap.
  • Pull out the power plug.
  • In the case of hard-wiring: turn off the electricity supply, remove the fuse and disconnect.
  • Check float microswitch and float of styrofoam.
  • Find and remedy water lakeage in the bottom of dishwasher.
Dado
Jan 22, 2015 | AEG Dishwashers
Aeg
Here is a link to the manuals site - I suggest you search by PNC number (you should find it on the label somewhere)
http://www.aeg.co.uk/Support/Manuals/
Apr 09, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Favorit 44070 3 flashes on end of cycle light. No water loading. Does not start
you need a water valve if the overfill float is not malfunctioning
Aug 27, 2012 | Bosch Dishwashers
AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Feb 02, 2009 | AEG 24 in. Favorit 3A Free-standing...
Access to flow thru heater
On the 40660 washer this element is in line with the top sprayer arm pipe and is at the back bottom of the washer. Easly reachable by removing the back bottom plate. Has a clamp on each end and a electrical push on connector.
Apr 22, 2008 | AEG 24 in. Favorit 40650 Free-Standing...
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
AEG 24 in. Favorit 80800 Free-standing Dishwasher Logo
Top AEG Dishwashers Experts
Mike
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
