Question about Ricoh Office Equipment & Supplies
Ricoh 3224 j063 - Ricoh Office Equipment & Supplies
Set a 3224 casio
Try Googling (casio)(3224)(manual) without parens to get instructions.
Jul 29, 2017 | Casio Watches
Ricoh 3224 Prints have fading in the middle of the page?
Verify the OPC drum and the polygon motor scanner glass,something is dirty.
Feb 13, 2013 | Ricoh Aficio CL3500N Laser Printer
HOW DO YOU GO TO SERVICE MODE ON A RICOH AFICIO 3224.I JUST FILLED THE OIL BUT STILL GETTING SAME ERROR SC570.DOES THE OTHER PIPE ON THE OIL TANK CONNECT ANYWHERE BECAUSE IT IS JUST HANGING THERE.
Hello Peter,
Once the device has been neglected for oil long enough you will get this error code. Usually people don't wait until the code occurs. You WILL INDEED need to go into service mode. To do this,you will need to follow a fluid 3 step process. First locate the "CLEAR MODES" key located obove the 9 key pad. It is yellow. Now locate the red STOP button located below the 9 key pad.Ok, to enter service mode you will need to press "Clear /Modes"and release,then press the numbers "1,0,7" in a 3 step sequence and release, then press the red STOP button and HOLD it down till the device beeps. The screen will change and say service mode. Press "COPIER". The screen will change again. Using the keypad press 5,8,1,0 and then press the pound sign {#}. You will be prompted/asked to EXECUTE. Press EXECUTE. Now unplug the device while in service mode after the execution of the 5810. Wait a sec, plug her up, and you are done. Have a good day and let fixya know I helped. :-) SPINAL
Jul 23, 2011 | Ricoh Aficio 1232C Color Copier
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
Gestetner DSC332 SC393-02
Hello klwhite,
The answer to your question:
Savin.......3224/3828/2820
Ricoh......2232c/2238c/2228c
The error code means that there is a problem with the yellow dev unit. The manual says that "during warm up" the TD sensor saw .78 volts or less when it performed process control. We both know that this device may perform process control at times other than warm up. Sounds like the yellow dev unit is the problem as the sc393 means td sensor and the 02 means yellow developer unit. I truly hope I have helped you. Take care.........spinal......
Apr 25, 2008 | Gestetner DSc332 Copier
55 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
