Question about Olympus Software SP-610UZ Digital Camera
My Olympus SP-610UZ camera get restarted when i click on button to take pictures, help please, thank you
    Top Expert:
  • Olympus Master
  • 6,702 Answers
This can happen when you battery does not have enough power. It protects the camera against damage and the pictures on the memory card. If the camera has not enough power while accessing the memory, it could damage all pictures you already shot.
Even when you just charged the battery, it can be it does not have enough power to work. Just try charging it again and if possible try another battery.
Posted on Jan 02, 2014
Bogdan
  • 198 Answers
SOURCE: Need to clean
Hello sticky, This is a lens assembly mechanism problem. It is a delicate part of any camera. Altrought some people may sugest you to use a compressed air spray to remove the sand in the inner lens by blowing it out i don't recomand that because sand particles can be pushed out even further in the lens and could be causing even more damage. The lens assembly is composed of several servomotors, coils, some sensors and the actual lens. It does the following jobs: it extends the lens back and forth achieves focus by moving the lens zooms the lens by rotating them in the same time as the whole objective is moved back and forth Each of these operations is controlled by some servomotors who actually move these parts and are also connected to some sensors that pass the readings back to a main processing unit. When you open the camera this processing unit will check to see if the lens assembly is able to do all of these 3 things. Failure to comply with even one of them will result in some error (lens error) or simply having the camera not opening. "Lens error" or "zoom error" is a generic message, doesn't mean that the lens itself are damaged, could be the connector to their servomotors, sensor failure, some coils that are out of position and things like that. In your case the sand particles are preventing the servomotors to properly align the lens. They are all related to the lens assembly. Because this is a VERY fragile part of any camera I don't suggest you to try a DiY repair because you can damage the lens even further. Even service centers have problems repairing this, most time it is done under a microscope and some times it simply can't be fixed. This problems occur most of the time in corelation with the camera being dropped or received some shocks but even some small particles or sand in your case, can cause this problems as you can see. I would recomand you to go to a service center. Try not the big ones that represent large corporations (because they are expensive), instead look for a smaller one. Tell them you have a lens assembly problem, also tell them that it's caused by sand, ask them to make you a diagnostic and then ask for a cost estimate BEFORE they actually repair the camera. If the lens assembly is damaged beyound repair it will need to be changed as a whole, including all connectors, CCD sensor and so on. This could cost from $70 - $200 excluding labor parts that can be about $100. Therefore you should ask them a cost estimate. I'm sorry for not being able to provide a DiY solution but like i've said, i don't recomand one. In the future try not to expose the camera to any shock, sand or excesive dust and temperature variation. These are all known to give a great deal of trouble with digital cameras. If you need more info please post back. Good luck.
Posted on Apr 04, 2007
SOURCE: Zoom Error
Have you tried changing the batteries to new/charged ones?
Posted on Oct 17, 2008
  • 919 Answers
SOURCE: Hello, My Olympus u700 Camera displays an error code "D: 5e02, 5f08". What do I do? Please help! Thank you. Regards.
The problem you are describing is a problem with the sensor in the lens assembly. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $86 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on May 08, 2009
  • 11967 Answers
SOURCE: Zoom Error with my Olympus SP-550uz
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
richard191
  • 691 Answers
SOURCE: Hi Ive got an Olympus SP-550UZ digital Camera
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. "Zoom error" is repairable
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Feb 21, 2010
How do you delete images on the Olympus sp 310
The delete button is above the LCD monitor on the back of the camera, the second button from the right, marked with a trashcan. While viewing the picture you want to delete, press this button. The camera will prompt to make sure you want to delete the picture.
Apr 19, 2012 | Olympus SP-310 Digital Camera
Damaged liquid crystal display
No display on screen can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using fixya
Aug 11, 2011 | Olympus Software SP-610UZ Digital Camera
I have an Olympus SP-700 for around 4 years now,no probs,when I clicked on the icon this evening to download some pics I keep getting the message Olympus Master .exe has encountered a problem and needs to...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Jan 08, 2011 | Olympus SP-700 Digital Camera
User Manual for an Olympus SP-350 8.0 Megapixel Camera?
You can download and print the instruction manuals in PDF format by clicking these links:
Basic Manual
Advanced Manual
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Oct 14, 2010 | Olympus SP-350 Digital Camera
I havea an olympus sp-350, shutter is stuck so
I had the same problem, so tried putting the zoom fully on to take a picture.
It worked.
May 12, 2010 | Olympus SP-350 Digital Camera
How do I get the date stamp on my Olympus SP-510 UZ Digital Camera pictures?
The SP-510 will not deface your pictures by scrawling numbers across them. However, the data is stored with every picture. Depending on the program and printer, you can print the date on the image, in the margins, or on the back. Please refer to the documentation for the program.
If you print directly from the camera, refer to the instructions in the "Printing" section of the camera manual (page 46 in my copy).
Sep 28, 2009 | Olympus SP-510 UZ Digital Camera
My Olympus SP-310 has wavy lines in all the pictures. I found a solution before on the internet - it recommended changing one of the settings. However, I can't remember what it was, and I can't find t
If the camera was working fine "before" you made a setting change, try going into the setting and selecting "factory Default" That may correct the setting you may have experimented with. And, make sure your battery is fully charged first!
May 25, 2009 | Olympus SP-310 Digital Camera
I have a problem with my Olympus SP- 510 UZ digital camera: Although it perfectly displays pictures taken recently, the screen remains all black when I intend to take pictures. It does take pictures...
Sounds like a repair issue with the image processing chip in the camera. You may want to call Olympus Customer Service to discuss repair options and pricing. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 12, 2008 | Olympus SP-510 UZ Digital Camera
Downloading pictures from Olympus SP-320
you will need a USB camera lead to plug to the PC then you can copy all of your pictures to the computer
kind regards and please don't forget to rate us
Dec 08, 2008 | Olympus SP-320 Digital Camera
Olympus Software SP-610UZ Digital Camera Logo
35 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
