Question about MTX Thunder 421D Car Audio Amplifier
30 fuse keeps blowinn
I keep puttin fuse in there and it blows it
    Sergeant:
    Champion:
  • 227 Answers
That means that you have a short in the power supply or in the output circuit.
Posted on May 21, 2009
30 amp fuse keeps blowing on my Honda deauville 650
30 amps seems too high for any bike.... But any time you keep blowing fuses...there is a bad short somewhere check all the wiring for that feed; worn wires, bad connections, and faulty equipment on that feed service.
Good Luck
Jerry
Jun 10, 2016 | 1998 Honda Deauville NTV 650
30 amp starter fuse keeps blowing on 98 cherokee
you may have a short (verify the integrity of the insulation of the positive wire from that fuse going to the rear window defroster, check the relay & switch.) try to replace the relay.
Oct 03, 2015 | Cars & Trucks
1999 ford super duty relay coil keeps blowing fuse. truck wont start. why?
Some of those trucks had a heater coil in the fuel filter bowl. It would short out and blow the fuse . Try unplugging the wire just behind the bowl ,and replace the fuse again. that may fix the problem.
Feb 18, 2015 | Ford Cars & Trucks
I have a 2009 hornet rv .my battery is fully charge but two 30 amp fuses keep blowing out whets the problem
you have a dead short someplace better get a mechanic to check it over .
Feb 18, 2015 | Cars & Trucks
Why i keep blowing a fuel pump fuse?
Hey Paula, if it keeps blowing that could mean a short in system or more so the pump is having trouble pumping it is 20 years old also check the fuel pump relay
Oct 17, 2014 | Cars & Trucks
2002 chevy 1500 keeps blowing #1 injector fuse
IF YOU HAVE CKED FOR A SHORT THEN MOST LIKELY YOU HAVE A BAD INJECTOR. YOU CAN UNPLUG ONE INJECTOR AT A TIME UNTIL IT STOPS BLOWING FUSES OR YOU CAN TAKE IT TO A REPUTABLE TECH WHO CAN HOOK IT UP TO A SCAN TOOL AND IT SHOULD SHOW THE BAD INJECTOR.
Dec 11, 2012 | 2002 Chevrolet Silverado 1500
I keep blowing a 30 amp fuse on a 2002, 1200 S Suzuki bandit
Have your voltage regulator checked a bad regulator will blow big fuses like a 30amp, hope this helps.
Sep 08, 2012 | Suzuki GSF 1200 Bandit S Motorcycles
30 amp fuse keeps blowing i was able to change it and it would start now it just blows at the turn of my key
If the 30 amp fuse blows there is fault or short within the igntion /fuel pump circuit. You need to check this case by ISOLATION. remove connection of the suspected sections one by one and confirm when the fuse blows as the particular circuit is connected.
Dec 23, 2011 | 2006 Pontiac G6
The engin control fuse keeps blowing on my 2005
your fuelpump could be causing the fuse to blow as it may be seizing up
Apr 18, 2009 | 2005 Ford Focus
MTX Thunder 421D Car Audio Amplifier Logo
66 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
