Question about Cell Phones
Motorola z8m not charging.when i connect charger display this massege check connecting
jaffi
  • 8 Answers
SOURCE: NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Posted on Feb 16, 2008
SOURCE: not charging
your phone charger might be the primary problem...
Posted on Jun 22, 2008
VOTIT
  • 2071 Answers
SOURCE: Have a motorola v3X Suddenly not charging
Just replaced a new cable or a new charger so you sure where is the defected even if battery defected it will charge but the battery it will not last long.If you replaced already new cable but problem still exist then the problem is the cellphone hub is crack or cold solder,you need to rebuild or resoldered it so it will works normally.
Got to cellphone to perform the soldering.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 28, 2009
  • 125 Answers
SOURCE: N70 not charging
Here is a generic solution for all mobilephones!
This problem could be caused by either battery, charger or firmware failure. you can try the following to secure which!
-Try your mobilephone with another charger or connect it to a PC using a USB cable
> if ok? the problem is your charger!
-Try your mobilephone with another battery
> if ok? the problem is your the battery!
-Try your battery and charger on another phone
> if ok? the problem is your mobilephone/firmware :(
If you dont have access to other phone, battery, charger or USB-cable you can at least try the steps below:
1. Turn off your mobilephone
2. Take out your battery, Sim-card and memmory-card
3. Connect your charger
4. Put the battery in
5. Turn on the phone
If it doesn't help, with a little luck! you should get a USB-cable, back yor phone up and reset it to factory default and upgrade your firmware/software on the phone to the latest version!
OBS! You should only do it with a fully charged battery! or you could damage your phone irreversibly!!!
Posted on Jul 12, 2009
SOURCE: charging problem
hi
When i am put chaging at the same time it's showing 'NotCharging"
.Please help me and give me the solution
Posted on Aug 17, 2009
Motorola xoom wont charge
this is very common/same problem lots people having with their tablets, but i recently found solution for it.... try the following.
first connect ur charger to the table as you normally would do for charging, then connect the tablet to the computer through the USB wire (make sure charger and usb wire both must connected to the tablet) and it should start charging.... this seem awkward but will 100% work try it and see it urself
Feb 03, 2013 | Motorola Mobility XOOM Android Tablet
How to play mp3 songs in motorola z8m
i can play mp3 file my motorola z8m
Mar 16, 2011 | Cell Phones
Motorolla peble
It's Italian for "unable to charge"
Motorola phones won't always charge with non-Motorola chargers, or via USB connections.
Does it do this with a Moto charger or a generic one?
Dec 21, 2009 | Motorola Cell Phones
Unable to charge battery
Clean charging port, remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Oct 19, 2009 | Motorola Mobility RAZR V3
I just bought a motorolaq Z8m here in korea its in english for the most part but i never recieved a disk with the paches to connected to my pc
I have the same phone as well, I am in south korea too.
Go to http://www.mymotorola.co.kr/product/PrdDownProduct.aspx?id=0036 and download the softwares so you will be able to connect your phone with your pc. This website works better with Internet Explorer.
1.First download and install the "SKT USB DRIVER"
2.Download and install the "PC SYNC" you have to choose one, the english "yeong-mun" or the korean "hankul"
Those are the important ones you need first...
Thanks
cas..
My own problem with this phone is that i can't find a Voice Answering feature in it. And i can't play any video/audio file i put in the SD memory card in this phone.
Aug 03, 2009 | Motorola Mobility MOTORIZR Z8 Cellular...
"unable to charge"
I had an old Motorola V3, which used to show me that error. It could result if the charger is not firmly connected to the phone. To diagnose this, try borrowing someone's moto charger. It's also possible that battery contacts could have dust. Try dusting them off so that they're nice and shinny as usual. Finally, try removing the battery for a few minutes, reinsert and charge, leave the phone off when you charge. The phone usually starts working after the regimen. If the problem persists, you'd know which method worked and what failed, so you can press for a warranty. Cheers
Jun 02, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Charger of my v3i unable to charge.
probably a bad charger try someone else's I had this happen once from the many phones i had (that and the dog ate the wire on another)
Jan 05, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Not charging
Jun 22, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola battery charging prob....
change the batteries or have the board reflash to correct errors
Mar 04, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
My cell won't charge
I've had similar problem, and found that if I jiggled the charger prong, that it can make a connection. Sometimes, the connection is dusty or just not hitting the receptors in your phone. Hope that helps.
Apr 24, 2007 | Motorola Mobility V551
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
