Scanner km 6025 Problem
I have problem in Scanner this machine, in copy become black out paper, in print it's become good . when do zoom in ( error code f127 ) zoom out no error code. other problem cassette 1 failure . Thank you ^_^
4 Suggested Answers
  • 2072 Answers
SOURCE: Copystar 1635 copier/printer set up problem
What the problem sounds like is that the machine and print driver are set to diifferent paper types.
One says plain paper and the other bond paper.
Or something like that, the machine says bond and the printer plain paper.
Chech the size setting and paper orinentation.
Most of the time the paper type is wrong. Also check paper color etc etc. Something between the machine and driver is mismtached.
Posted on Feb 12, 2008
SOURCE: Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Posted on Aug 15, 2008
darshanthapa
  • 3 Answers
SOURCE: xerox DC12 error code 3-380
your sensor in IBT unit is not lined up accurate with the white sticker in the film.....solution is - deassemble the ibt unit and reassemble it...worked for me....
Posted on Dec 02, 2012
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
Black copies being received
Your image scanner is bad. Try making a copy....if it comes out black but your incoming faxes are fine then your image scanner is bad. You can also print a report from the machine and it should come out fine.
The image scanner is the part that scans your originals before faxing them out or making a copy. There is a light bar that lights up when scanning. Either that light bar(l.e.d. array) has gone bad or the scanner itself is bad. If this is the case it is probably going to cost more to fix than the machine is worth. You could buy a new machine for what it would cost to fix.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Digital replacement for Canon NP 6025
"No" is the answer to all of those questions, and even if it were "yes", purchasing a good quality refurbished digital machine from a reputable supplier, would still be a far cheaper option than all of that.
Not in or around Toronto, are you?
Mar 12, 2009 | Canon NP 6551 Black and White Copier
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
3-INCH WIDE VERTICAL LINES RUND DOWN LEFT SIDE OF FAX MACHINE
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Dec 11, 2008 | Office Equipment & Supplies
NP 6025 printing Crooked
yes ther is ! first clean the glass with Mr Sheen(which is a spray on furniture polish) the glass needs to be slippery so the paper slides nice and easy over it.Then if that doesnt help,where the feeder attaches to the machine are 2 hinges one of which you should be able to adjust. Hope this helps.
Aug 19, 2007 | Canon NP 6551 Black and White Copier
jasbo
jasbo
