How to display picture on Samsung HDTV from Toshiba BDX2400KB Blu Ray Player Clicked 480p on blu ray players settings and now it just says on the TV MODE NOT SUPPORTED
    Sergeant:
  • 302 Answers
I think it's got something to do with 1080??
Posted on Jan 02, 2014
How can I change the language on a sam-sung blu-ray player?
How To Reset Your Blu-ray Player To Factory Defaults (BD-C & BD-D Models)
Page 1
Page 1. Reset Your Blu-ray
  1. Power on your Blu-ray player and tune your TV to the input where the Blu-ray player is connected. For example, if the Blu-ray player is connected to HDMI 1 press the TV input/source/line button to tune your TV to HDMI 1.
  1. Remove any disc from the player and then press and hold the Stop button on the front of the player, not the remote, for about 8 seconds or until the front display reads 'SETUP'. 'Resetting all settings to default values...' is displayed on your TV screen as the Blu-ray player powers off and resets.
    1. The Blu-ray player is automatically powered on after the reset and the select Language screen is displayed.
Aug 16, 2014 | Samsung Televison & Video
My Sansui SLED 2453W 1080p HDTV will not support my Toshiba BDK33 blu-ray disc player.
try to force resolution below 1080p to interlaced, or 720 and see what happens..you may have a bad logic board
Aug 20, 2012 | Televison & Video
Blu-ray player mode not supported
Is your TV 1080p? If the Blu-Ray is putting out 1080p and your TV only supports 720p/1080i then you will get a message like this. Try changing your settings to 720p while it is connected to a TV that does display correctly, then move it back to the 47 in LCD.
Jul 08, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
How do I go from 480p to 1080dpi on my 65inch HDTV
If you're using an HDMI cable your display will automatically adjust the settings based upon the video source. Make sure that your source is capable of outputting 1080p. If it's an HD Cable Box or DVR, the maximum resolution it can display is 1080i. If you have one of these HD boxes, set it to only display 1080i as there will be a delay every time you change channels from a channel that is not naturally at 1080i.
If your source is a standard DVD player, it can only display images in 480i (or 480p if it is Progressive Scan) and therefore your TV will display the picture in 480 resolution. If your source is an upconverting DVD player it will display up to 1080p however, Keep in mind that DVD's are in 480 resolution and that regardless of upconversion (or upscaling, though improved, the picture will not be in HD.
The only way to achieve a true 1080p (not dpi... that's dots per inch... that's a printer term. The "p" is for Progressive Scan as opposed to an "i" for Interlaced) is from a 1080p source, i.e., a Blu-Ray disc player playing a Blu-Ray Disc with the use of an HDMI cable. Component Cables can achieve 720p/1080i only with your TV as it does not support 1080p over component cables.
As an aside, there are some media players that support 1080p output and some DirecTV Boxes and DVR's d oas well for 1080p Pay Per View movies.
Nov 23, 2010 | Mitsubishi WD-65733 65" HDTV
I cannot get video signal from my Samsung p1590 Blu Ray player via HDMI to pass through my Onkyo TX-SR606 AV Receiver. I get video if I connect Blu Ray player directly to TV, and have tried all HDMI ports...
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Onkyo TX-SR606 Receiver
My Viewsonic N3751W 37-Inch LCD HDTV always shows 480p
your dvd is set to 480p. if it is a convertable dvd player set it to 1080i. the tv sets itsef to whatever the dvd player displays. if not all dvd is 480 to 720 p. blu ray will get you top notch 1080 display.
Jul 07, 2009 | ViewSonic N3752w 37 in. LCD TV
Is a blu-ray player compatible with a rear projection tv phillip?
You need to use an HDMI connection from blu-ray player to the television. If your tv does not have an HDMI input the tv is probably to old and will not accept 1080P. If it does have an HDMI connection it should display a minimum of 1080i.
Jan 29, 2009 | Zenith E44W46LCD 44" Rear Projection...
Dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Jan 10, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
Jul 22, 2008 | Samsung BD-P1400 Blu-Ray Player
Televison & Video Logo
Top Televison & Video Experts
